Boot Items
ScottD3 Aug 11, 2011
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,122
    Bit of a odd request this but it should all be come clear in the next couple of weeks if it works out.
    What do you fellow B5 owners feel are important tools and items to carry in your boot?
    Speakers, subs and amps don't count..............Not yet any way.
    Spanners, sockets and tools will be on the list but not sure what are the most common sizes for the B5s.
    Any ideas?
    The list at the moment is:=-
    Spare bulbs for each style of bulb
    Cleaning wipes
    fire extinguisher
    water spryer
    cloths
    Big hi-vis jacket
    hi-vis vest
    can you think of any thing else this worth carrying for holiday travel or day to day?
  2. B5QUAT
    B5QUAT Member
    317
    13
    Torch
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,772
    32
    I carry a foil poncho thingy and a fleece. I was once stuck waiting on a motorway embankment for over 3 hours for the RAC to turn up. I was freezing! Went out the following week and bought one.
    Fuses. Don't leave home without them these days. That 3+ hour wait was all because of a blown fuel pump fuse!
  4. audiv8quattro
    audiv8quattro Member
    443
    9
    A 10mm 13mm and 15mm socket, intact just grab a little tool kit with sockets in but I've found that near enough every bolt on mine is either one of these sizes, oh and an 8mm
  5. aragorn
    18,369
    828
    The only things in my car are the jack and an axle stand, a high vis vest, jump leads and a tow rope, plus the standard wheel brace and accessories (locking wheel nut key, puller for nut covers etc)
    A bulb set might be handy (and is required for some foreign countries). Fuses themselves can be stolen from other fuseways in a pinch though. You dont typically NEED everything in there, so if stealing the heated rear screen fuse or similar gets you home then you can do without the heated screen for a bit.
  6. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,749
    656
    Just the standard Audi tool kit, in the 15+ years I've had Audi's, I've only had 1 tow which was when the icm module failed.
  7. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Hammer?
  8. denzelburner
    denzelburner Member
    166
    I keep some marigolds, head torch (both for changing a tyre etc when on way to/ from work), disposable poncho, space blanket and hi vis vest, a a little orange flashing led thing for if my electrics have gone, which can sit in the rear window, and as andiv6quattro said, a few different sockets, plus fuse and bulb set. It all fits neatly by the cd changer/ around the spare wheel I find
  9. LeeT
    LeeT Member
    429
    RAC card. I can fix most things but why bother? im insured :D
  10. Goosey
    Goosey Member
    61
    kitchen sink?
    first aid kit is worth keeping, to me it's tools being a first aider, but if you came to a scene of an RTA then even if you wouldn't know what to do with your bag of bits someone else might
