Boot failing to lock - part number confirmation needed
Leebo310 Apr 24, 2014
  1. Leebo310
    Leebo310 Member
    37
    I've done a bit of research and it seems that this isn't an uncommon problem. I've tried some wd40 on it as per some of the suggestions I've read but that didn't make any difference (other than staining my boot lining! :mad:) so I'm looking to actually replace the part.
    I've spoken to my local Audi and they think the part may be 4F5827505D but I just wanted to run that past the gurus on here before commiting to actually ordering one?
    Thanks in advance!
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,037
    785
    That is the correct number.
    Leebo310 likes this.
  3. Leebo310
    Leebo310 Member
    37
    Thanks mate, much appreciated!
  4. Leebo310
    Leebo310 Member
    37
    I fitted the part on the weekend and the boot now stays shut so that's a bonus!
    Only issue is that it now can only be unlocked with the key fob boot button. The central locking option on the mmi is set to unlock the boot when I unlock the car but this doesn't happen and instead I have to press the boot button on the key fob.
    Any ideas how I fix this? I've tried changing the settings in the mmi to reset it but that didn't work.
  5. B5NUT
    4,037
    785
    Have you checked / cleared fault codes, sound like the central locking system still thinks there is a fault condition causing the system not to work, and resetting the MMI system will not change any of the faults on the central locking.
  6. Leebo310
    Leebo310 Member
    37
    There are no lights or errors on the dash and the boot shows as closed (before it was constantly showing as open) but I presume I'd need a proper diagnostic to confirm if anything is actually there?
  7. B5NUT
    4,037
    785
    Yes either find someone local with VCDS or find a local VW/Audi specialist, the dash will not report any errors on the central locking system.
  8. saxonblue
    saxonblue Member
    298
    15
    I had the same thing on an A4 cabriolet I had a couple of years ago, get the fault codes cleared off and you should be fine
  9. Leebo310
    Leebo310 Member
    37
    Ok cheers, will try and find someone local that can clear it for me!
