Boot Door Sensor
bkmullin Jul 1, 2005
  1. bkmullin
    bkmullin New Member
    10
    Hi All
    My DIS is constatntly diplaying my Boot as being open, when it really is closed.
    Does anyone know where the sensor in the boot is?
    Many Thanks
  2. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    if its anything like the doors, the switch is integral to the lock, and is not a servicable item.
    requires complete new lock if its knackered.
    def a warranty job if you got one. They are not cheap.
  3. clarko
    clarko Member
    it looks like the sensor is to the right of the latch. I may be wrong. Try cleaning it, looks like 2 electrical contacts.
  4. HTC
    HTC Active Member
    3,428
    9
    The boot lock can be removed and pulled apart. I had to fix mine last year as it had a small amount of corrosion within it which effected the microswitch for the alarm.
    Took a few hours, but I saved some pennies.
  5. My driver's door does it too - particularly in hot weather. Booked in to Audi dealer for warranty fix.
  6. bkmullin
    bkmullin New Member
    10
    I went out at lunch time and had a play around with the latch. I got a screw driver and wiggled it around inside, and hey- presto the display now shows it closed when closed, and open when open!!
    Not very scientific, but I'm happy now...
  7. The Slug
    The Slug Active Member
    1,869
    they have adjusted the door or lock and is fine, just wasnt catching correct or sommut only in there for an hour max and they got me in the next day which was pretty gud too
  8. mazzy
    mazzy Member
    303
    i have it on my driver door, but i got some wd40 sprayed it into the latch are on the door all corners in ther hole, clicked the latch & sprayed again & used a cloth with wd40 on the chassis side to clean the bracket. Aint happened since...
    Try that people. /ubbthreads/images/graemlins/froggie_red.gif
