Boot area's sprung a leak! Help please!
Dani_B19 May 15, 2013
  1. Dani_B19
    8,879
    304
    So i thought id fix this but clearly not.
    At first i thought it was the rear drivers light was leaking, fitted facelift lighs a while back and i thought it was them, took them out and silicones the rubber area and fitted all back together and id get the occasional little leak in the sparwheel well but then it stopped.
    Checked today after 24hours of none stop rain and guess what, theres a puddle again, took the rear side panel off and had a feel around and its actual above the light fixings, now last time i checked water doesnt rise unless underpressuer so whats leaking?
  2. Scullies
    Scullies Well-Known Member
    1,541
    651
    could it be the antenna base?
  3. Dani_B19
    8,879
    304
    Doubt it mate, water is only on drivers side, no electrical faults or damp rear roof!
  4. ChrisS385
    ChrisS385 Member
    37
    rear window washer jet they can leak in to boot
  5. Dani_B19
    8,879
    304
    Not used it mate but when they leak in runs through the lock, the water is actualy coming from above the rear light.
  6. s3mad_dude
    s3mad_dude Noggies ruuuule!
    596
    77
    Rear window seal might be a culprit. Check it from inside with the seats down and crawl through. Perhaps get someone to pressure wash the boot as you check??
  7. Dani_B19
    8,879
    304
    But wouldnt that leak down the boot lid area etc and not in the side storage hole?
  8. Grale1
    Grale1 Active Member
    795
    44
    X2 for the rear washer I had a similar thing recently, I would get a wet spare wheel well even when there was no rain, turned out I had a loose connection on the rear washer jet
  9. Dani_B19
    8,879
    304
    Ooh i know that mate, ive had my fair share of leaking wiper motors but i dont use it for that very reason but like ive said the water isnt coming from the wiper motor as itd leak through the boot trim itself or lock and it isnt, its coming from the drivers side up near the light.
  10. Dani_B19
    8,879
    304
    So few people on vag talk have said ariel base so going to give this ago along with siliconing everything up lol, wheres best place for a new ariel base?
  11. Dani_B19
    8,879
    304
    Right ive siliconed the **** out of the ariel base so theirs no chnace i can be from their and im still gettig water coming in from the drivers side rear quarter. Any ideas?
  12. Scullies
    1,541
    651
    Could the side window not be sealed and the water is finding its way down into the boot area?
  13. jay1601
    jay1601 Well-Known Member
    1,299
    49
    dunno if you got a sun roof, but the run off pipes from the sun roof runs down thought the side of the boot panels.
    had this problem with my other A3
  14. Dani_B19
    8,879
    304
    Nar scullies the waters too high for that and itd leak from the seat area etc.
    cars non sunroof jay so int hat either. Its baking my skull in nar lol.
  15. epox
    epox Active Member
    772
    74
    is there not a joint in the washer at the pillar? try removing all the water from the washer system and leave it a few days and check just to be sure it aint the washer system
    mark
  16. Dani_B19
    8,879
    304
    The joint i believe is around the passenger side. Its definately a leak mae as it hasnt rained for for a few days and the boots bone dry so isnt the washer system as if it was its be wet constantly?
  17. Greig300
    Greig300 Member
    253
    I'd say rear washer hose happend to mine.
  18. Dani_B19
    8,879
    304
    How can it be the rear washer though as the jet doesnt get used and the leak isnt around a joint area!
  19. G60DAN
    G60DAN Member
    364
    It's not the rear washer it leaking on the drivers side and the rear washer pipes are on the passenger side. This sound like a funny one can't say I like water leaks so hard to find where there coming from good luck. If you ever sort it let us all know where it was coming in from.
