Boosting Help
AudiA4B596 Aug 29, 2012
  1. AudiA4B596
    AudiA4B596 Member
    68
    Hey guys,
    First thing I did was installed the boost gauge and fitted it in line between the manifold and the DV... (correct?)
    Stock psi on the gauge was maxing about 6-7 psi.
    Then I'm confused about this N75, I've bought a boost controller (bleed valve) separately, removed the existing connections on the turbo and waste-gate and fitted the new bleed valve from the turbo to the waste-gate, and blocked off the other lines that were there previously (I believe these go to the N75?)
    ..but is this wrong because at about 6-7 psi the car starts jumping/cutting out and it seems as if that's the maximum the car's ECU will allow although now its trying to boost more, just keeps jumping/cutting...
    Could it be the plugs misfiring now? Do I have to have the new bleed valve and N75 both connected in-line? Is there an upgrade to the N75 you can buy? Could it be that my waste-gate has been set to a limit of 7 psi?
    I'm a bit confused why this happening???
    I was hoping to get between 15-20 psi at a safe level as I have heard others are doing and I have an upgraded DV, intercooler and air-filter as some supporting mods.
    Could someone please help me out...
    Many thanks
  2. steady jay
    steady jay Member
    184
    I'm no expert but I think with these cars the MAF/ecu controls everything. If the ecu hasn't been chipped/flashed/remapped you simply won't get more boost.
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Hope that helps....
  4. aragorn
    18,663
    878
    You've probably plumbed it in wrong.
    Forget messing around with bleed valves and have the car mapped properly. If the ECU sees the car overboost it will just cut off the fuel. You cant tune these engines with a bleed valve.
  5. AudiA4B596
    AudiA4B596 Member
    68
    Thanks guys,
    Im going to move the boost gauge pipe and put everything else back to normal, and consider getting in mapped, although it costs 7000kr (£700) in Norway... so will have to save up...
