  1. Drizz
    Drizz Project Plush
    681
    Im guessing the 1.8t is a little different from a Vauxhall LET so i cant just adjust the actuator slightly for more boost?
    I know it sounds cowboy, but on the Vauxhall engine you could tweak it slightly and it made a fair bit of difference. Im guessing Audis are a bit less neanderthal LOL
  2. Broken Byzan
    13,237
    465
    As you are facelift, you should have a map sensor too, so if you adjust the actuator the ECU will just use the N75 to eek the boost down to whjat its expecting to see
  3. Drizz
    Drizz Project Plush
    681
    oh ok, ill have to wait for the exhaust then remap it then. :(
  4. Oranoco
    Oranoco Well-Known Member
    3,974
    405
    The setup on these cars is quite clever. No shortcuts or cheap fixes. not sure what the standard injectors flow to either.
