  1. 97_A4_1.8Turbo
    97_A4_1.8Turbo Member
    50
    how much PSI should a stock 97 b5 a4 1.8T producing???
  2. johnyj
    johnyj Member
    264
    mine goes to 0.5 if thats any help mines a 99
  3. 97_A4_1.8Turbo
    50
    is that in bar or psi?
  4. Markey
    Markey Active Member
    2,175
    [SIZE=+1]0.5 bar = 7.25188689 psi
    [/SIZE]
  5. 97_A4_1.8Turbo
    50
    thanks
    yeah mines pushing close to it sometimes i got it up to around 9psi dont know how cuz i have a boost gauge and i glanced at it and it was reading 9psi is that a good or a bad thing?
  6. PaulJC84
    PaulJC84 Owner
    2,921
    17
    It may spike at times slightly higher. I wouldnt worry unless it goes a fair bit over.
    Get a remap though then you will get the gauge to go higher.
  7. 97_A4_1.8Turbo
    50
    wat exactly is a Reamp
  8. Markey
    2,175
    Where they upload some code onto your ECU which will adjust the fuel and boost control and etc which gives you much more power 35+ BHP
  9. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Its tuning for people with dyslexia.
  10. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    You'll find that peak boost is well before the redline (and is quite literally a brief peak).
    The higher the revs, the more air your engine is using, so your turbos can't keep up with peak boost.
