boost problems on 1.8t
harris91 Apr 12, 2013
  1. harris91
    harris91 New Member
    19
    some times in 2nd gear on wards the car seem to loose boost for few seconds then come back again, ive just put brand new turbo on it and this also use to happen on the old turbo that was fitted before , any ideas?
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Boost leak? Bad map on the car?
  3. harris91
    harris91 New Member
    19
    already checked pipes couldn't find any leaks , would it be good chance of being bad map then?
  4. Vex182
    1,035
    79
    Could be, if everything mechanically is sound, then software could be a issue. Is the MAF all good?
  5. harris91
    harris91 New Member
    19
    Well I've code read the car an there's no fault codes , Il give the maf a clean tommorow and see if that helps then
  6. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Boost leak mate.... I had this and was confident I didn't have one. Get a smoke these if you can't find it.
    Mine was after the intercooler
  7. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    +1
    Though mine was a split breather hose and took me ages to find it....
