Boost problems A3 TQS GT2871
STEALTHQUATTRO Sep 1, 2012
  1. STEALTHQUATTRO
    STEALTHQUATTRO Member
    116
    So what gain can I get going the full monty with high revs? Al need solid lifters won't I? And hydraulics and what's your thought on high lift cams?
  2. badger5
    9,543
    2,022
    dude.... one step at a time fella..
    for your frame turbo, you wont have the flow to want or need revs...
    bigger frame unit, more flow, more revs... then the rest to go with that..
    maybe concentrate on getting what you have running right first?
  3. <tuffty/>
    21,578
    4,050
    ^^^ +1
  4. STEALTHQUATTRO
    116
    Ahh I see, I know the turbine is a .86 a/r not .64.
    Al get the map sorted by bill sometime next month I hope then Am going to collect all my parts for the winter re-build.
    Av got 3rd synchro going to do may as well do it all at once!
    I just need to know what's the best for this turbo.
    Al have a look threw the forum!
    Please dont laugh but has anyone pit a vortech on these for bottom rev range?
  5. aragorn
    18,491
    855
    Select the turbo properly and you wont need a vortech.
  6. STEALTHQUATTRO
    116
    Yea but surly you don't get low end power with a big turbo that's why I mentioned!??
  7. <tuffty/>
    21,578
    4,050
    What is it you are after exactly??? this thread is getting very confusing and you haven't fixed you current setup as yet lol...
    Nobody has done a supercharger conversion on an 8L on this forum that I am aware of so you would be the first... I would imagine you will need to go standalone ecu for that though as the ME7 will not be suited to a supercharger...
    Big turbo's aren't that bad to drive... I have a GT3071 and its fine... yeah its 'laggier' than a K04 but when you are on it you don't notice and pulls like a train...
  8. STEALTHQUATTRO
    116
    Yea sorry bout that! Lol
    It's just bit Laggy round town but then I don't want to sacrifice the high end big numbers!
    It was just a thought. Ta
  9. <tuffty/>
    21,578
    4,050
    the low comp pistons you have won't be helping and a bit more timing advance lower down may be possible to make it feel better around town... I don't have that issue tbh... mines fairly lively all things considered...
  10. aragorn
    18,491
    855
    get it mapped properly and i'm sure it'll be a completely different car to drive.
  11. STEALTHQUATTRO
    116
    Yea al get bill to sort it out then over winter al get the head and syncro sorted!
    Al defo sell the stainless exhaust valves and go inconal!
    Av found the valve guides and they are supertech manganese bronze are these any good as mike recond the oem ones are better?
    These valves I have got are nitrated does that make any difference?
  12. <tuffty/>
    21,578
    4,050
    No idea on the supertech guides as never used them personally but OEM ones are fine... can't see the supertech being any worse...
    Nitrated inlets are fine...
  13. badger5
    9,543
    2,022
    you are chasing the unachievable.... it will be laggier on a 0.86 hotside than on a 0.64 one...
    stroker will recover spool, and billet turbos will remain compact and deliver flexible power and torque delivery...
  14. badger5
    9,543
    2,022
    EV80 black nitrided is what they are, fine for inlets, but not my choice for exhaust valves on a turbo car personally. Inconel is what I use.
  15. STEALTHQUATTRO
    116
    Cheers bill for the advice of checking out the oil pick up!
    Av cleaned her out and now I carn't even hear the hydraulics at 2k! Well quiet!
    I checked the vvt and the grooves don't look bad! If they are grooved by manufactures ad say it's those grooves!
    So with the head: Keep nitrated inlets, Get inconnel exhausts!
    So do I just need new oem springs with these valves?
    Do I need new lifters?
    What colets do I need?
    Do I need to get the large port head checked out as the timing belt snapped and all valves was bent!
    Some of the bearings are polished a tad!!
    Mike said the guides will be ok to use because none of the valves were snapped!
    Can someone start me a new thred on this head topic please.
  16. <tuffty/>
    21,578
    4,050
    Yes
    super tech triple groove valves are designed to use OEM parts... you can use your existing springs and collets...
    Not unless yours are no good...
    Get it checked to make sure its not warped or cracked and get the guides checked as no doubt the exhaust ones will need replacing... relap all the valves back in and use new stem seals...
    You can do that yourself :)
  17. STEALTHQUATTRO
    116
    Cheers tuffty!
    Here's some pics of my head they seem ok, just. Few black spot pits,polish marks on loabbs and lifters circular marks and yellow wear edge on top edge:
