Boost pressure control valve
imported_SYNAPS3 Sep 6, 2004
  1. imported_SYNAPS3
    imported_SYNAPS3 Guest
    After changing to a Forge diaphragm with a strong spring in my S3, I got the following DTC:
    17608 – Boost Pressure control valve (N249): Mechanical malfunction
    P1200 – 35 – 00 –
    Should I revert back to the stock DV or use a weaker spring. IS this fault and the new DV related.
    Where can i found the boost pressure control valve. If anyone has a pic, kindly post it please.
    Chipped S3's with Forge FMDVR/FMDVRA's, which spring works best?
    SYNAPS3
  2. HTC
    HTC Active Member
    3,428
    9
    The N249 valve is the DV.
    You need a spring that holds just over the max boost pressure that your turbo is producing.
    If you have a too weak spring the valve will open before it should an d the car will surge under acceleration.
    Anyways, at a guess I would go for the yellow spring for your application.
