Boost Pressure Control Valve (N249) : Open Circuit
Jamo2013
Somerset
Hi All,
Upon scanning the car, i got this code - and when using a multimeter to check the wiring at the valve end, i got no reading. Tried searching around for suggestions after this but no joy! Can anyone point me in the right direction as to what i can do next?
Many thanks.
Jamie
You should get 12v across the n75 plug wiring. The points might be loose, try checking the power supply a bit further down the harness.
edit, sorry I can't read :(
n249 is different to n75
have you done the n249 delete?
Thanks for your inputs. heres where i am now -
Got power readings which are fine and done a resistance test on the n249 valve and that seems fine. Next suggestion? Can anyone explain what 'Open Circuit' means? i assumed it was like a broken cable!
Cheers!
Also - It has been bypassed, had this code since i bought it, but finally trying to get it fixed :)
Have you tried clearing the code? Maybe it was an old fault that's not been cleared.
