Boost or map problem please help
djdougalno1 Dec 9, 2009
  1. djdougalno1
    djdougalno1 Member
    189
    driving my car home all was going well then tried to go on boost nothing there like it was in limp mode but it wasnt it has been mapped buy a.m.d was boosting 1.3 1.4 bar but now wont boost past 0.5 cant see any leaks ie oil water or boost any help or ideas would be great
  2. Terrier QTS
    Terrier QTS Member
    41
    Leaky DV? Are you running OEM or after market?
  3. djdougalno1
    djdougalno1 Member
    189
    runnin bailey dv 30
  4. S3KO4
    S3KO4 Member
    850
    have you just put boost guage on? i have noticed my boost drops on high gears becuse the intake hose colapses, you wont be able to easily test this as it needs load to show it. but that could be a factor...
  5. pauldazzle
    pauldazzle Well-Known Member
    1,131
    81
    Max of 0.5 bar sounds like limp mode to me.
    You need to get vagcom on it.
  6. djdougalno1
    djdougalno1 Member
    189
    thanks for the ideas but sorted it today it was a split pipe going from the charge pipe to the n75 couldnt see it in the dark but this morning there it was so problem solved an didnt cost a penny :arco:
