boost on 96 20v turbo aeb
20va4 Jun 22, 2011
  1. 20va4
    20va4 Member
    hi im new to my audi a4 its got a boost guage i runs about 7psi on full boost then drops to about 4.5/5psi is this right
  2. Bradderz_1988
    3,958
    238
    Yes That's right for 150hp on stock ecu as I've just learned as mine was running that on the 180hp and it should be 12psi so am in the process of eliminating my boost leak :slapped:
  3. 20va4
    20va4 Member
    ok thats good i seen yours thought i would find out just got my a4 yesterday hant had a turbo before lol does a boost controller do much
  4. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    my 150bhp APU engine is showing 10-11psi peak and holding 7-8psi(ish)... bit odd
  5. aragorn
    18,437
    845
    APU runs a different ECU and different boost control though, so its possible that explains the larger peak.
    I guess it also depends what the OP means by "drops to 5psi". I'd expect it to tail off near the top end of the rev range, but it should hold 7-8psi thru most of the revs.
