  1. markthenewt
    markthenewt Member
    250
    Hi guys...
    This is my first turbo car so don't know much about them.
    I thought the sound I get when flooring it is the turbo, the sound I get is like a pssssssssssh noise, like blowing sound... is this a boost leak?
  2. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,368
    909
    Not necessarily, best thing to do is pop the bonnet with the engine on and listen for any hissing and see if you can do a visual check to see if you can see any split pipes....do you get any jerkiness when you floor it or any engine management lights on the dash??
  3. markthenewt
    markthenewt Member
    250
    Can't hear any hissing with the bonnet open nor is there any splits in the pipes that I can see, however I have not managed to check the pipe going to the intercooler properly as it's too tight to get in, really need the front end off to check that eh?
    No management lights on either now (repleyed in other thread) but I do get a hesitation if I drive it slow... just before the turbo kicks in it like holds back for a split second then carrys on fine.
  4. DenCar
    DenCar Member
    404
    The pssssssssssh i get when above 2000 rpm is the turbo spooling up, if i lift off it stops.
    DC
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    If its driving ok leave it, you dont need to look for trouble in these cars... they will soon surface if there is anything wrong
  6. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    It's just turbo spool up mate nothing to worry about. Upgrade the TIP (Turbo Intake Pipe) with a Jetex air filter and hear the spool up noise you get with that! ;)
