Boost leak from Inlet manifold injector inserts, advice needed
S3 ROCKS Jun 2, 2013
  1. S3 ROCKS
    S3 ROCKS steve
    228
    Hi all. Well to cut a long story short I removed my inlet manifold and had it polished up. I done all the good stuff, replaced the injector port plastic caps that sit in the inlet manifold, and replaced the injector seals as well as a new gasket of course.
    The problem I had was that when fitting the plastic caps to the manifold they wouldn't give any indication of when they were tight. They would keep winding down on the thread untill the top hat section would just crack. I ended up cracking 3 out of 4 they are such a bad design. So a trip down to the stealers was needed, to purchase more
    I have fitted them all, and sealed them using sump gasket sealer. But I am getting a hissing sound from what sounds like the 4th injector. Has anyone ellse replaced these caps. And if so what did they use to seal them in to stop any leaks?
    Audi workshop manaul makes no mention of any sealant to use and it states they are only torqued to 2NM.
    Any help would be appreciated. I'm considering getting a garage to test for boost leaks to see if its any of the vacuam pipes underneath the manifold as they are very dirty, have moved them around when the engine was at idle though and there was no drop in rev's so I think I can rule these out.
  2. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    Find a place that can do a smoke test.
    Also, dre_s3 on here recently replaced his, me might be able to give you some tips.
    do your injectors have new o-rings??
  3. S3 ROCKS
    S3 ROCKS steve
    228
    Yeah I'd considered the smoke test. But I've just moved to teh Highlands, and I know finding a garage here with one is gonna be tough. First I have to find civilization lol.
    I changed all the O-rings as well. And theirs no noticeable fuel leak.
    I leak checked the manifold etc using washing up liquid but didn't get any bubbles coming up.
    I've asked Andy as he just made his own manifold. See what answers I get
  4. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    I have my inlet manifold off at the moment because my injectors are leaking, I have purchased new injector o rings and new plastic seats, I have removed the old seats they were very tight to remove the threads on my manifold look like they have loctite on them this is what I was going to use, I won't be assembling till Wednesday so if you find out what audi recommend to use please could you update the thread so as I know what to use thanks
  5. Adam Davis
    Adam Davis Member
    49
    Hi mate, i replaced both injector o rings and the plastic inserts a couple of months ago after doing a boost leak test and every injector was leaking :/
    I used plumbers ptfe tape and it worked a treat :) there very brittle and mine didnt seem to have any kind of sealent when removing.
  6. dusty
    267
    46
    Did the new seats screw down ok with ptfe on them? How many times did you go round the seat with the tape thanks
  7. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    ptfe tape is hair thick so id say go round twice at least. its also very soft so itll be crushed in the threads as well , which is the idea, but if i were doing it id do it at least twice round, dont forget to pull tight as you wrap it round.
  8. superkarl
    9,623
    2,488
    Id have thought any sort of silicone sealant would suffice.
    Also make sure your injectors are seated properly in the seats, they should require a tug to remove them.
  9. dusty
    267
    46
    Just had a quick look on eBay and you can also get a ptfe sealant I wonder if that would be any good
  10. S3 ROCKS
    S3 ROCKS steve
    228
    Thanks to everyone for the comments. The sump sealant I've used should more than suffice as a sealant. So I may try winding them in further when teh manifold is hot, and hope they don't crack.
    I think a smoke test is the way forward to see where the leaks coming from.
    Dusty theres nothing in the Audi workshop manual stating what to use to seal them, when asking Audi they said they've never had to repace them before. I'd suggest any sealant for high temp areas. Hence why I used sump sealant. Or use PTFE tape as suggested in a post.
  11. Adam Davis
    Adam Davis Member
    49
    Oh god i wrapped it a fair few times, i use it for air line fittings all the time at work. Threads in no problems as said above it squashes right down so as long as you dont go mad its fine. Probably 5-6 times.
