Boost Issue - Boost Pressure Regulation: Control Range Not Reached
RobinA3 Jun 10, 2010
  1. RobinA3
    RobinA3 Well-Known Member
    1,826
    46
    Drove the A3 this afternoon and noticed that it wasn't boosting properly, part load is fine but go into WOT and there is a massive drop in performance.
    Scanned the ECU and got the following fault code:
    16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
    Did a search on the internet for info and got this:
    Possible Symptoms
    Reduced Power Output
    Limp Mode
    Possible Causes
    Hoses/Pipes incorrect connected, disconnected or leaking
    Charger Pressure Control defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check / Clean / Replace Charge Pressure Control
    Special Notes
    When found in 2.0l TFSI:
    Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06F-145-710-G (or newer), see TPI 2016331 for details.
    I changed the recir valve 4 years ago when i remapped the car to the type ' B' level which was then the uprated item.
    Looks like i will be doing the job again this weekend on the driveway, anyone had this same issue recently?
  2. RobinA3
    1,826
    46
    Issue found, it was the divert valve that was split. Price of the part has gone up from £25 to £45!!!
