Boost gauge plumbing
Markb Aug 11, 2004
  1. Markb
    Markb Active Member
    2,139
    After reading this Thread which has a lot of discusion about which pipe to plumb into.
    I am unsure which pipe to plumb into.
    Has anyone got any pics from their 1.8 T Sport or Quattro showing the pipe I should be using? As I am confused and don't want to get cutting the wrong pipe LOL
    Also is it OK to just cut the pipe?
    Is a plastic T piece OK?
    Finally what about clips around the T Piece?
    Cheers Mark.
  2. paulbinks
    paulbinks Member
    56
    The pipe you need is the one fitted to the fuel pressure regulator which has a direct feed to the inlet manifold and will be the most accurate feed and a plastic tee is ok to use.
    Cheers "Bingo" /ubbthreads/images/graemlins/beerchug.gif
  3. jojo
    28,935
    3,588
    Mark, I took this feed as recommended by Rai, as it comes directly off the inlet manifold, works perfectly.
    Also, is there any reason why you can't feed the tube for the boost gauge without the 12mm bolt on it?
  4. jojo
    28,935
    3,588
    Heres a picture of my boost gauge that I was suppose to post up in the other thread, excuse the poor quality and the finger prints on the glass are from pressing the silver button to death changing the colours lol
  5. Markb
    Markb Active Member
    2,139
    Hmm I think I am going to have to take some pics of the pipes under my bonnet and you will have to direct me LOL
  6. Markb
    Markb Active Member
    2,139
    OK the layout on the S3 must be different as I can't see the pipe that I should be after.
    Here are some pics from under the bonnet:
    Anyone know which one I should be after?
  7. peteA3tdi
    peteA3tdi Member
    408
    that don't look like my S3 i have a big metal pipe off the turbo with the dv line and w/gate pipe on it
    also anyone with a boost gauge do your gauge's go into the minus before going into the plus
  8. pure
    pure Member
    340
    the pipe u need to cut into is at the front of the engine. Post a pic of the whole engine bay mate.
  9. peteA3tdi
    peteA3tdi Member
    408
    can you not use the pipe that go's to the waste gate from the big metal pipe off the turbo(maked in red)?
  10. paulbinks
    paulbinks Member
    56
    Hi all
    if you use the same line as jojo you may get a flicker or erratic reading as your car goes on boost, this is where i first plumbed in my defi boost gauge before reading the instructions which stated it needs to be a direct manifold line before any vac/solenoid valves, and recomends the fuel pressure reg line which is at the end of the fuel rail above the injectors just below the coil packs by 3-4 inches.when my gauge was fitted like jojo's it went wild as it came on boost as all the valves on that line opened and closed.
    Cheers "Bingo"
  11. jojo
    28,935
    3,588
    Maybe it's time for another Midland meet and have a browse of Markb's engine bay in the process lol.
  12. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    LOL not a bad idea.
    The gauge is now in place in my custom A pillar mount and looks good. I just need to get it plumbed in. I might take it to a garage as I don't fancy making a mistake /ubbthreads/images/graemlins/frown.gif
    I am confused on which one to use as AMD said use any vacum hose /ubbthreads/images/graemlins/confused.gif
    I will post a pic of the whole engine bay tomorrow when I get chance.
  13. Markb
    Markb Active Member
    2,139
    So do I take it to a garage? Or can anyone give me some more advice and I'll do it myself.
    I still need to buy the brass connector, but I am not sure which pipe I am going into so I don't know the diameter.
  14. jayfrts
    jayfrts bouncing off the limiter!!!!
    92
    Mark,
    Let us know where you get the brass connector from dude!
    Jay
  15. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Any plumbing/hose specialist can supply them.........I get mine from a company called "HyperHose"
  16. jojo
    28,935
    3,588
    Mine came with the boost gauge.
  17. jayfrts
    92
    Mines a Ebay special!!
    Well i hope this 'BEST PLACE TO PLUMB IN ISSUE' get sorted soon as i want to fit mine.
  18. ill take some pics of where mine is plumbed in, but i believe its off the fuel reg hose.
  19. HTC
    HTC Active Member
    3,428
    9
    You guys are missing the obvious place to plumb a boost gauge.
    Whats the one thing thats directly connected to the inlet manifold but won't effect the running of the car etc.....
    ......the brake servo.
    If you follow the servo pipe from the inlet to where the "one way valve" is in the line, then you will see a green plastic cap just before the valve.
    Just pull off the cap and fit the pipe for your gadge. No cutting or tee piece required.
    Sorted.
  20. Markb
    Markb Active Member
    2,139
    I suppose you are right there HTC, but could you direct me to that pipe?
    I am good with other stuff, but don't normally touch engine parts LOL
  21. HTC
    HTC Active Member
    3,428
    9
    I'll take a pic later and post it up when I get in from work for ya.
  22. Markb
    Markb Active Member
    2,139
    I've got some other pics from under the bonnet as requested:
    [image][/image]
    [image][/image]
    Also what does eveyone else think about going into the brake servo hose?
  23. HTC
    HTC Active Member
    3,428
    9
    Your pics don't seem to work for me.
    Anyways, here are some pic of the servo vacuum pipe and the green cap you can remove.
  24. Markb
    Markb Active Member
    2,139
    Cheers for that HTC
    What DV are you running? Doesn't look standard.
    What are others peoples views on using the brake servo vacuum hose?
    Here are the two pics that didn't work:
  25. HTC
    HTC Active Member
    3,428
    9
    I'm running a forge piston type DV.
  26. S3tony
    S3tony Member
    395
    just curious but do you guys leave your covers off your engine or just removed for the photographs?
    cheers tony
  27. HTC
    HTC Active Member
    3,428
    9
    I just took them off for the pics. I think the 1.8t engines are ugly looking things without them! /ubbthreads/images/graemlins/vomit.gif
  28. S3tony
    S3tony Member
    395
    good point just checkin.....
    cheers tony
  29. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    cheers tony
    [/ QUOTE ]
    Yeah mine is just off to take some pics /ubbthreads/images/graemlins/wink.gif
  30. Markb
    Markb Active Member
    2,139
    So is the brake servo pipe a goer?
    What do think guys?
    Also I take it that I would have to fit the T Piece after the one way valve?
  31. HTC
    HTC Active Member
    3,428
    9
    I'll do some testing if I get time over the weekend. As far as I can tell the side of the valve that the outlet is on is "before" the valve, so it gets vacuum and boost pressure.
    If this is the case then you won't need a tee piece, you just connect the pipe from the gauge to the outlet.
  32. Markb
    Markb Active Member
    2,139
    Cheers mate /ubbthreads/images/graemlins/wink.gif
  33. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    foolish3uk said:
    why dont you just put a 'T' Piece in right next to the fuel pressure regulator, that is where audi say to check the bost pressure so it is good enough t fit the boost guage there.
    [/ QUOTE ]
    People have stated in other threads that it can cause problems with the running of the car.
    I don't know how true this is as I've not experienced it first hand.
    I'm planning to mess about with locations when I get my gauge.
  34. Dean_T
    Dean_T Active Member
    645
    139
    43
    have you tried giving someone like Jabbasport a ring and asking their advice? /ubbthreads/images/graemlins/smile.gif
  35. RichA3Turbo
    5,089
    When i fit mine it will be well easy! The IHI has a take off on the boost outlet of the turbo which can be used for a boost gauge. If its not used, then you just blank it off. EASY! /ubbthreads/images/graemlins/grin.gif
  36. jayfrts
    92
    So this issue still hasn't been resolved............
    Someone take the bull by the horns! /ubbthreads/images/graemlins/tongue.gif
    HTC have you finished your testing yet??
  37. HTC
    HTC Active Member
    3,428
    9
    LOL, I did actually forget about this........oops.
    Anyways, I don't have a boost gauge any more. Gods know where it went. Probably got lost when I moved house. I need to pull my finger out and order one.
    Markb, as it sounds like you have the gauge fitted, I would simply plumb in to the various places suggested. Just drap the pipe (safely) round the engine for a trial. See which works best for you.
    Also as you've reminded me that I need to get a new one, I've emailed a guy in the states to send me a new one. So I'll be fitting that when ever it arrives.
  38. RichA3Turbo
    5,089
    Im in the process of doing this... fitting boost, oil temp and oil pressure...i could do with knowing all of them now! Just trying to make up my mind as to which gauges to get... Its achoice between Apexi EL02 or Defi D-Gauge.
    Rich
  39. HTC
    HTC Active Member
    3,428
    9
  40. Add7
    Add7 Member
    310
    where did you get this from HTC and how much?
