boost gauge help
derek84 Apr 28, 2012
  1. derek84
    derek84 Member
    67
    Hi I went to wire my boost gauge in today was gonna do it off the headlight switch but the loom isn't long enough for me to pull out and work on. Any ideas as to where else I could wire from (pics please am rubbish with this sort of thing) or how can I get a more slack on headlights loom cheers Derek
  2. jay1601
    jay1601 Well-Known Member
    1,344
    73
    anything which comes on with the headlights. i've ran mine off the light near the cig lighter (lights up the area under the centre console)
  3. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    I ran mine into the air vent light. Mine has illuminated vent scrolls.
  4. derek84
    derek84 Member
    67
    I don't have illuminated vent scrolls and I dont have a light under my center console well not one I can find anyway
  5. andyw82
    andyw82 Member
    46
    do u have a headlight ajustment switch, i used that on m4 a4 as it illuminates when light on.
  6. derek84
    derek84 Member
    67
    Yeah but as its too short for me to be able to work on :(
  7. jay1601
    1,344
    73
    why not just make the wires longer. so your able to connect to something easy to get to ?
  8. actualeddie
    actualeddie Member
    211
    I put mine in the vent to the right of my steering will and wired it up to the headlights switch. Where you aiming at fitting your gauge?
  9. Vwdan80
    Vwdan80 Member
    100
    Hi just take the lower dash panel off under the steering wheel to get to the headlight switch loom better :)
    actualeddie likes this.
  10. derek84
    derek84 Member
    67
    It's in the vent next to the headlights switch I pulled the headlights switch out and the block that connects to the back only just reaches the hole so for me to work on it I need to be able to get my hand in the headlight switch recess I am gonna extend boost gauge wires anyway cod they are only about 10cm long anyway
  11. derek84
    derek84 Member
    67
    Was just replying when u wrote that will have a loooook in the mornin
  12. actualeddie
    actualeddie Member
    211
    i stripped the wired half way up from the switch and taped them on, would have soldered but couldnt find an iron.
  13. Vwdan80
    Vwdan80 Member
    100
    The lower panel comes off easy and will give you loads of room to work
  14. actualeddie
    actualeddie Member
    211
    How'd you get the vacuum tubing in without taking the panel off?
  15. derek84
    derek84 Member
    67
    I ain't done that yet I just want to make sure I have everything clear in my head Before I start tryin to wire in properly Cos sods law if I had plumbed it in then found out I couldn't wire it where I would of liked
  16. actualeddie
    actualeddie Member
    211
    Fair enough. Once the covers off from under the wheel it should be easy. 3 screws i think 1 in the fuse box
