Boost gauge fitting help
millsy75 Mar 29, 2013
  1. millsy75
    millsy75 Active Member
    274
    Hello, is there any chance somebody could post a picture of where they've fitted the T piece under the bonnet?
    I'm trying to fit the stack boost gauge to my S3 8L, after feeding the vacuum pipe into the engine bay I need to see where people have put the T piece into which pipe? All the pipework seems too big for the T piece.
    A photo of somebody's engine bay with a boost gauge fitted would be a great help.
    Thank you.
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    tee in to your dump valve vac, dont tee in to the fpr as if you get a leak it will mess your fueling up dude :)
  3. <tuffty/>
    21,013
    3,776
    N249 feed is a decent enough place to start... the pipe coming off that is small... don't tap into the FPR pipe though... its better that the FPR has its own feed
  4. millsy75
    274
    Thanks, could you direct me to a picture at all? I'm still a bit unsure. Sorry to be a pain.
  5. Lemon S3
    Lemon S3 Alex
    1,390
    41
    The small pipe that's attached to the top of the DV.
  6. <tuffty/>
    21,013
    3,776
    I wouldn't fit it there unless you have done an N249 bypass... fit it to the pipe leading up to the t-piece of the N249 if you haven't done the bypass
