Boost gauge centre vent install?
voteforpedro Jun 16, 2009
  1. voteforpedro
    voteforpedro Member
    632
    I've bought a 52mm boost gauge which I planned on fitting in the centre or driver-side vent tomorrow. However... stupid question time... what is stopping the installed gauge from rocking up and down as the vent pivots? :hubbahubba:
  2. docurley
    4,070
    85
    It should be quite tight and I never had an issue with my old vent gauge.
  3. aragorn
    18,300
    805
    I've recently installed an oil pressure guage, and found that the guage was deep enough to reach quite far back into the apature meaning it would only move a few mm's up and down.
    I put some sticky foam pads above and below the housing to hold it tight so it doesnt move at all now.
    I did have to remove the flap that controls the airflow though, as the guage hits it. So i put duck tape over the rear of the housing so the air wouldnt blow past the guage constantly.
  4. voteforpedro
    voteforpedro Member
    632
    I forgot to mention that it's a universal gauge and I'm going to "modify" the existing vent.
  5. docurley
    4,070
    85
    Thats what I did.
  6. aragorn
    18,300
    805
    same!
  7. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    I ziptied the wires going into the back of the gauge to the vent housing. That keeps it pretty secure.
    I did fit one of those in-vent Ambi-Pur air fresheners a while ago which was quite heavy. Just got a small piece of black cardboard, folded it and wedged it in on the underside of the vent which holds it solid.
  8. Geeman
    Geeman Low Life
    1,318
    This is my next mod too... going to retro-fit the boost gauge I have in the centre vent.
  9. voteforpedro
    voteforpedro Member
    632
    My boost gauge came but I have a question! I heard the fusebox is the best place to wire it up but they gave me a very generous wire length of around 0.25m so there's no way it will reach from the centre vents.
    Rather than extending the wire, where else can I splice into? The three wires go to:
    - 12v ignition switch
    - Vehicle ground
    - 12v dash lighting
  10. Blue_Thunder
    1,771
    31
    Do you not have any other wire lying about? I had to extend the wiring that came on mine to reach the dash terminals (switched live).
