boost brake line 1.8t agu
A3-20VT Jun 20, 2012
  1. A3-20VT
    A3-20VT New Member
    can i change this hose with aftermarket sillicone hose with same diameter? only the section that come from the manifold to the check valve
  2. <tuffty/>
    21,686
    4,116
    Sort of... problem is that the larger ID silicon vacuum pipe isn't very stiff and as this pipe sees vacuum then it can collapse which of course would be bad...
    You can get smaller ID in proper laminated silicon hose though and is what I have used on big turbo builds in the past
  3. A3-20VT
    A3-20VT New Member
    Well i installed a sillicone hose that is ID8mm OD14mm worked perfect
