Bonnet won't close, help please guys.
cossie Aug 31, 2010
  1. cossie
    cossie Member
    79
    As the title suggests im having great difficulty getting my bonnet to close. This happened a few months back but i got it shut after a few attempts but now its just taken about half an hour. The bonnet release catch inside the car is ok and going back into place (not open position) and i've sprayed wd40 on bonnet latch? and bonnet catch mechanism. I've also tried to adjust the little rubber gromets on the bonnet so they are shorter but dont know if these would affect it. Anyway i got it closed a few times but i gave the bonnet a pull up the way to make sure it wouldnt fly up whilst traveling at speed but it still kept popping up. Eventually got it closed but as i said it took half an hour and a lot of banging and swearing, not ideal. So can anyone help me with a fix i can do or has anyone else came across this problem, sorry for the ramble guys, cheers!
  2. aragorn
    18,134
    764
    i'd imagine its the lock has siezed up or is gunked up with *****.
    If you get someone to pull the release arm while you look at the mechanism, you should be able to see the linkage that moves over, Its probably not moving back to the "locked" position. Might be able to free it up if you apply some oil and work it back and forward.
  3. cossie
    cossie Member
    79
    Cheers mate, I'll give that a go.
  4. Foxmeister
    Foxmeister Fired Up!
    1,785
    As Aragorn said mate, few people have had the same problem.
    Although the handle in the car returns back to postion, the mechanism under bonnet will be stuck open slightly due to lack of maintenance etc. Needs a clean out, then some new grease and worked a bit.
    damn_seagulls likes this.
  5. cossie
    cossie Member
    79
    Cool, thanks mate.
  6. damn_seagulls
    damn_seagulls New Member
    Old thread I know but many thanks for the above Aragorn / Foxmeister.
    I too found myself smashing the bonnet down and swearing in the street on Friday night before taking a train as I wasn't sure whether the safety catch alone would hold out for 2 hours on the M1.
    I just got a chance to take off the lower bonnet latch, soaked it in degreaser repeatedly then drowned it in WD40 before working it with a pair of pliers until it was freely clicking back and forth again. Put it back on, dropped the bonnet from a few inches up and CLICK. Locked perfectly without any pressure from above. Cheers!
  7. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,702
    158
    Job well done. Did you put some white grease, or any other type of grease, back on latch? If not, it will quickly seize up again after removal of the original/old grease...
    Dan
  8. damn_seagulls
    I did my best to get regular engine grease in there by dipping a piece of card and pushing it down the gap. I got a bit in there but it was such a small gap I'm not satisfied. I am going to buy spray grease later today.
    S4_dan likes this.
