bolt length?
Plunky Mar 24, 2010
  1. Plunky
    Plunky Member
    522
    Does anybody know the standard bolt length of the bolts that connect the rear calipers to the hub on a 2wd a3?
    Liam
  2. rossbrownlee
    rossbrownlee Ross_S4
    719
    Do you mean the caliper onto the carrier?
    or the carrier onto the hub?
  3. Plunky
    Plunky Member
    522
    sorry yeah the carrier onto the hub
  4. Imteyaz
    Imteyaz 6th Gear
    535
    Hello mate (good to meet you at R-Tec a few weeks ago BTW!), according to ETKA, the carrier to hub bolt is: M10x1,25x30 (that's for a rear caliper on the 2WD and 4WD A3) I haven't a clue what that all means but I'm sure someone much more knowledgeable will be along soon to translate that in laymans terms...
  5. salsheikh
    salsheikh New Member
    24
    have a look at screwfix, i think they sell that size.
    hi B!
  6. rossbrownlee
    719
    30mm length.
    they are cheap from audi dealer.
  7. Plunky
    Plunky Member
    522
    i only ask as i need slightly longer ones as i am fitting a 256mm upgrade on the rear and have to use 6mm spacers between the carrier and hub thus needing slightly longer bolts :D
  8. Plunky
    Plunky Member
    522
    Hello buddy, was good to meet you too, always nice seeing a fellow forum user! :D
    thanks for the measurements :D I think the 1.25 part is the thread size, someone correct me if im wrong though :)
  9. Keeno
    Keeno Spooly Spooly Boosty Boosty!
    701
    M10 is the bolt size (diameter) 1.25 is the thread pitch and 30 is the length IIRC
  10. Plunky
    Plunky Member
    522
    would a 40mm bolt be ok to use with the 256mm upgrade? or will it be too long?
  11. Plunky
    Plunky Member
    522
    anyone?
