Boilers gone!!!! F*£@
Dazmo Jan 20, 2011
  1. Dazmo
    Dazmo Active Member
    1,762
    -4 tonight just left for work and the boiler has packed up. Fantastic
    Damn thing turns on and turns back off after a few seconds, no pilot light.
    Think it could be either low pressure or could be the flame sensor/probe at least thats what im hoping.
    Fortunatly i have Npower home team cover so going to ring them tomoro.
    You never think these things will happen to you until they do!
    Any got any ideas?
  2. jojo
    28,834
    3,488
    Dunno mate, but my shop one went when it was -16, and it cost me £3.5k to put right including a completely new central heating system! So goodluck!
  3. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,319
    766
    Condensation boiler?
    Your drain out pipe is frozen.
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Good shout, I was just about to say that!! lol.
    So so so common in the cold weather. Get outside and pour warm water on it to heat it up, and then insulate it with some lagging.
  5. Dazmo
    Dazmo Active Member
    1,762
    Well npower are sending an engineer monday, so i have 2 f&%£@ing days of artic conditions.
    Soon i will be scraping and de icing my tv before i can watch it, im most worried about not having the heating on and my pipes freezing up.
    Where the hell is the drain out pipe? i see no pipes out side i just had a flu thing?
  6. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    I'm sure that story cheered him up no end!
    Mine was low pressure when this happened. What's the gauge reading ?
  7. beanoir
    beanoir Large Member
    2,171
    30
    Dazmo - does your contents insurance cover damage in the house (like that caused by water leaks, frozen pipes etc)? Worth checking for piece of mind.
  8. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    What make and model is the boiler, that would help.
    Most condensing combi or conventional boilers now do not have a pilot anyway, they light up with a shower of sparks from a spark generator.
    If its an older boiler, it might be the fan that's packed up, its very common.
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    mine kept on freezing outside, (condensing waste pipe) till i knocked the mofo of the wall, been fine ever since
  10. Allroader
    Allroader Audi 3.0 V6 TDIs every time
    101
    Without the boiler make/model it's like asking 'my car won't run for more than 2 seconds' You'll get answers like:
    I have a Potterton Prima F from 1995 that did the same thing and it sort of got worse in the preceeding months. A quick check of the reset switch underneath showed that with some pressure (flexing the circuit board) the boiler would light. Google tracked this as a common fault with this circuit board so before shelling out £40 for a swap or £80 for a 'new' one, it was out with the soldering iron to freshen up the joints underneath. That was six months ago and the boilers worked every time since.
    Hope the engineer's visit is/was OK.
    Derren Brown (no, not really)
