BNS 5.0 to RNS-E conversion
CornRattle May 1, 2012
  1. CornRattle
    CornRattle Member
    151
    The fault log only manifested itself since moving the BOSE pin, B7 was occupied with the aux pin ( this was just removed and taped until I get the block for the RNS)
    With the BNS I had full voice control but not so with the RNS, all I can do is use the phone.
  2. CornRattle
    CornRattle Member
    151
    Very quick one chaps, I hope anyway.
    RNS-E part number 8P0 035 193 G
    SW version SW200
    HW version H06
    Would this support SDS?
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    my unit is h and spports it
  4. NHN
    29,298
    1,701
    G wont support SDS
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    my h unit is a good price, will potentially trade it for other bits:happy:
  6. CornRattle
    CornRattle Member
    151
    PM sent
  7. pherbert
    pherbert Member
    37
    Ok, have managed to get the DSP menu option up with VCDS, which isn't normally shown on the RNS-E/Bose black edition factory setup, however even with the Gala setting set to off, I'm still having the volume issue on startup!! It seems I'm not the only one, is there really a fix for this out there?? Starting to pee me off now!!
  8. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,062
    I had the same, it doesnt work for the volume, but it may cure the hiss some people have.
    Only this guy knows.......but he refuses to talk??
    pherbert likes this.
  9. pherbert
    pherbert Member
    37
    Yeah I must admit the hiss is much better than when I had my BNS5.0, but poor show there is no permanent resolve.
    Would really hope that somebody could crack this with so many examples of it happening!
    Does the moving of the pin that's discussed help matters, from what I can tell my Bose is working fine, however I have lost the use of of my Aux-in for some reason!!
  10. NHN
    29,298
    1,701
    OEM Auxin is wired into a 32pin connector on rear of rns, on the other models it uses pins within the quadlock, so they have to be moved.
