bluetooth stays on??
syk919 Feb 8, 2013
  1. syk919
    syk919 Member VCDS Map User
    66
    hello
    just intsalled rnse and bluetooth and had coded so all seems to be working.
    i think i may have an issue though. my phone says its still connected to the bluetooth module even when im in the house and switched everything off. although the car is still within range?? is this normal?
  2. jasonc
    jasonc Active Member Audi S3
    256
    No, not normal - Bluetooth on phone should disconnect within a few seconds of turning the ignition off.
  3. syk919
    66
    its still on. i think i should remove it. before it kills my brand new battery. arghh
  4. syk919
    66
    my version is 8p1862335 h44. if that helps
  5. Gourlay1990
    Gourlay1990 Member Team Glacier quattro Audi A4 Black Edition S-line owners group TDi saloon Manual
    39
    Could you not turn your Bluetooth off when you leave for the mean time instead of removing it? When I turn my ignition off my phone disconnects after a couple of seconds.
  6. syk919
    66
    yea i usually switch my bt off my main concern is the power drain il will have. i had something about some models being faulty thats why i got the latest one but it seems this is also faulty
  7. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,893
    724
    I think you may have a coding /wiring issue, I've not heard of any of the latest models having firmware fault.
  8. syk919
    66
    i did get the plug and play wiring? do you reckon it could be that?
  9. B5NUT
    3,893
    724
    What about the coding via VCDS?
  10. syk919
    66
    yea got the coding done by quite a reputable guy. might have to go see him again
  11. B5NUT
    3,893
    724
    If he was able to code it then the CAN wires are correct so the unit should switch off with the ignition. I would check the coding.
  12. syk919
    66
    ok i will get the coding checked again
  13. syk919
    66
    defo not the module??
  14. Tay
    Tay Active Member VCDS Map User
    449
    55
    I've got a feeling there is an option which is accessible from within the coding of the Telephone module to enable the phone to be continuously connected, but wouldn't have thought this would work when the car is locked.
  15. syk919
    66
    thanks for all the help got it sorted now. just bit of resetting and coding again
