Bluetooth Roof Aerial
Anito Mar 12, 2006
  1. Anito
    Anito Member
    434
    Morning All,
    I've got snow on the ground /ubbthreads/images/graemlins/laugh.gif
    Anyway, I was looking at the brochure for my car and as part of the Bluetooth Prep it says with roof mounted aerial (whiich I assume should be the fin) but my car doesn't have it.
    Anyone got thoughts about this? Is the aerial elsewhere?
  2. Davidb67
    Davidb67 Member
    152
    bluetooth is not a "wired" car kit in the old sense. it is a way of hooking up the audio from the phone to the car's audio/ICE set-up.
    More recently, we've come to see enhanced features such as access to the phone-handset's phonebook/sim content, and the ability to make/accept a phonecall from a steering-wheel button etc.
    additional tranmission power and aerial reception are no longer common.
    I think the "sharkfin" type antenna is an option/feature of satnav, although it will allow hook-up to GSM car-kits with external antenna out. i don't think you'd get the fin type antenna with just the phone prep.
  3. Anito
    Anito Member
    434
    I know it's not the same as the traditional phone kit but it is supoposed to proide an external antenna, hence my question.
    My car also has Sat-Nav, but no fin.
    cheers
  4. d5aul
    d5aul Member
    My new B7 avant has Mobile phone prep & DVD Sat Nav, it also has the 'Shark fin' antenna!
  5. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Why would you need any form of external antenna for Bluetooth?
    It only operates within the confines of the vehicle, having an external antenna would actually make the wireless connection worse as the cars earthed bodyshell acts as an electrical shield.
  6. With the BT prep you do get a cradle and antenna amp which connects to your sharks fin GSM antenna.
    In truth you don't need it, and would only use it if you had the cradle for your model of mobile phone.
    When you plug a phone into the cradle, it powers up the boot mounted GSM antenna amp.
    Hope that clears it up.
    Craig
  7. Anito
    Anito Member
    434
    [ QUOTE ]
    Craig
    [/ QUOTE ]
    So the antenna is in the boot then? How come it says the roof on all the material. Was it once on the roof and they moved it?
    cheers
  8. No, the antenna is on the roof for the GSM phone, which connects to the antenna amp in the boot.
    The BT module has a BT antenna installed into the module under the seat.
    What I said is when you insert a phone into the cradle it turns on the boot mounted antenna amplifier. the amp is connected to the sharks fin and is used purely for better reception in the car. Not for the bluetooth.
  9. TTLAW
    TTLAW Member
    128
    Strange but my B7 has the GSM/Bluetooth prep and no 'shark fin'!
    Maybe the design has changed?
    Steve
  10. Possibly, I know that they are now integrating a lot of the antenna systems into the rear window frame.
    Craig
  11. Anito
    Anito Member
    434
    [ QUOTE ]
    [/ QUOTE ]
    Craig, I'm agreeing with you, just used the wrong words in my reply. /ubbthreads/images/graemlins/blush.gif
    I am still left with the same cureosity. I have both bluetooth and SatNAv in my car. The roof has nothing
  12. The911SC
    The911SC Active Member
    1,032
    Yup, I have the gsm kit (cradle) but in the saloon, I dont think you get a sharkfin. Not sure where the aerial is though since there is a connection to it in the cradle?..
    Maybe Craig knows?
  13. If you haven't got a Sharksfin antenna then its in the center of the rear windscreen frame at the top.
  14. Anito
    Anito Member
    434
    Hmm, thanks for this, i'll take a look.
    Out of interest where did you get the info / diagram? Is ot from a CD manual or something that I can get my hands on?
  15. Nelson_R32
    Nelson_R32 Member
    305
    You only get a sharkfin if you spec RNSE Sat Nav and Phone Prep from factory.
  16. Anito
    Anito Member
    434
    [ QUOTE ]
    [/ QUOTE ]
    That's exactly what I have, but no fin
  17. The911SC
    1,032
    me too; i think you only get the fin on the avant?.. and only more recent ones I guess...
  18. Nelson_R32
    Nelson_R32 Member
    305
    The fin is only on B7's /ubbthreads/images/graemlins/wink.gif Every B7 with factory RNSE I've seen has had it anyway!
  19. Anito
    Anito Member
    434
    [ QUOTE ]
    [/ QUOTE ]
    me, me , me, me.. except the fin /ubbthreads/images/graemlins/tongue.gif
  20. imported_VERN
    imported_VERN Guest
    Sharkfin avant only 100%, with both dash mount gsm or arm rest gsm factory phone prep.......... even without nav, just been through all this @ dealers
  21. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Only in the US!
    In the UK we only get the sharkfin if: it's an Avant AND (you have factory fitted sat nav AND/OR factory fitted phone kit).
  22. VERN
    VERN New Member
    EH ??? thats what i said above and i am from the U.K
  23. PetrolDave
    1,559
    85
    But Anito said "Every B7 with factory RNSE I've seen has had it anyway! "
