Bluetooth Retrofit
MarcQuinlivan Nov 12, 2007
  1. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Anybody have the part numbers for all the bits required for retrofitting the bluetooth kit?
    I know VW have a couple of different kits available - the one I want is the one that allows you to use SIM Access Profile to connect rather that standard bluetooth for just the audio.
  2. s8craig
    1,753
    56
    You can't have SIM access in A3
  3. MarcQuinlivan
    2,539
  4. Vertigo1
    Vertigo1 Well-Known Member
    3,611
    705
    What exactly does the SIM access profile give you then?
  5. MarcQuinlivan
    2,539
    Standard bluetooth just takes the speaker and microphone and transmits these wirelessly, whereas SIM Access Profile captures the SIM card over Bluetooth and works like a fixed phone, so you get the benefit of an external antenna. It also downloads contacts and lets you read text messages. The mobile is then unusable as in effect there is no SIM card in it since it is being used by the car kit.
    I know the Parrot kits and some other kits also download your contacts but they don't capture the SIM wirelessly.
  6. Issac Hunt
    1,162
    That's correct, you can only have the SIM profile access on the MMI cars - A5, A6, A8 Q7 etc.
    All required part number info can be found in the quick links section over on http://www.navplus.us
