Bluetooth Phone Kit Coding VCDS Talk2Can AMI
Magpie2121 Jun 30, 2012
  1. Magpie2121
    Magpie2121 New Member
    9
    My first post, please be gentle.
    My car: Audi A5 (2010)
    Aftermarket kit purchased: Viseeo Talk2Can AMI
    Problem encountered: "Telephone Not Available" message on control unit
    I can pick up the Viseeo bluetooth signal and connect to the device successfully using my iPhone
    Coding instructions provided by Viseeo:
    A.With Sound System(Control Address 47)
    Setp1 :
    Gateway 19 Installation List ---
    2E - Tick Media Play3
    47 - Tick Sound System
    77 - Tick Telephone
    Enter 19 - CAN Gateway Coding - 07 : Codung value - 000303
    Step2 :
    Radio 56 Coding - 07 : enter Long Coding Helper ---
    Byte 1 : 02(Sound System Correction : Standard Sound System(Audi Sound)
    Byte 2 : 00(Speaker Channels:Sound System(No Speaker Monitoring))
    Byte 3 : 82(Bit7 : Long Wave Band blocked,Bit1:Telephone CAN-connection
    Monitoring)
    Byte 4 : 01(Treble Speaker Monitoring:Not Active)
    Byte 6 : Tick Bit 7 (Telephone control via voice control active)
    Tick Bit 2
    Byte 11 : Tick Bit 3(Mobile Device Interface(MDI) Setting active)
    Step3 :
    Sound System 47 Coding - 07 : Codung value - 0203010102
    I have coded the car using the above instructions and encounter the following using VCDS:
    Thursday,28,June,2012,12:50:26:53489
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
    VIN: WAUZZZ8T2BA031955 Mileage: 43010km/26725miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
    Component: R4 2,0L EDC H29 9098
    Revision: 25H29---
    Coding: 1A194012232503080000
    Shop #: WSC 00681 210 91360
    ASAM Dataset: EV_ECM20TDI03L906022NP A02009
    ROD: EV_ECM20TDI03L906022NP.rod
    VCID: 800543D21B18A29
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
    Component: ESP8 front H04 0030
    Revision: -------- Serial number: --------------
    Coding: 160504
    Shop #: WSC 06325 000 00000
    VCID: 7EF9BD2AE9EC549
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
    Component: BCM2 2.0 H04 0430
    Revision: 00002001
    Coding: 033400
    VCID: 800543D21318A29
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H50 0071
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T2 820 043 AE HW: 8T2 820 043 AE
    Component: KLIMA 1 ZONE H08 0180
    Revision: B1000000 Serial number: 01300920101969
    Coding: 34240000
    VCID: 75EBA206DCDA171
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000000670732
    Coding: 260050914034AF000009000300005D5D0F1D03080601010100 0000
    VCID: 3C7D7722BF70869
    Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 200910 H12 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 02532C
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
    Component: PARKHILFE 8K H06 0070
    Revision: 11001001 Serial number: 50941027910275
    Coding: 10020F
    VCID: 48951BF2FBA8DA9
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
    Component: AirbagVW-AU10 H41 0610
    Serial number: 003GKD0L02XM
    Coding: 30363438363030303030554A305238543053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 448D0FC2CF80FE9
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME5803263BB
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME58732D14H
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME46750726E
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME3F702122A
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME5170323CW
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME2B703F00
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
    Component: Lenks.Modul H06 0156
    Revision: 00000000 Serial number: 20101006000003
    Coding: 000016
    VCID: 49931EF6E0A2231
    Component: E221 - MFL H04 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8T0 920 983 B HW: 8T0 920 983 B
    Component: KOMBIINSTR. H40 0258
    Revision: 00100000 Serial number: EHY75K0AA
    Coding: 2F05300002002600010000
    VCID: 3D7B7A26A46A8F1
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0117
    Revision: GB800053 Serial number: 5300G1091583DF
    Coding: 00CF07
    VCID: 810346D61812AB1
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    3 Faults Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 216
    Mileage: 42841 km
    Time Indication: 0
    Date: 2012.06.22
    Time: 20:13:20
    Freeze Frame:
    Bin. Bits: 10000
    Voltage: 12.10 V
    Count: 12
    Bin. Bits: 10000
    02256 - Quiescent Current
    001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 231
    Mileage: 42870 km
    Time Indication: 0
    Date: 2012.06.22
    Time: 22:44:00
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 16
    Mileage: 42870 km
    Time Indication: 0
    Date: 2012.06.23
    Time: 02:44:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.70 V
    Count: 17
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1401
    Coding: 011C02624001450005
    VCID: 53AF3C9E32EE691
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0135538600
    Coding: 013B062220B904408020043680000000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
    Component: DSP STD H11 0440
    Revision: 00000000 Serial number: 00000000000001
    Coding: 0203010102
    Shop #: WSC 06325 123 12345
    VCID: 2F67506E7E066D1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 216
    Mileage: 42841 km
    Time Indication: 0
    Date: 2012.06.22
    Time: 20:16:27
    Freeze Frame:
    Voltage: 12.20 V
    Temperature: 29.0°C
    Bin. Bits: 00000001
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1401
    Coding: 011C02224001450005
    VCID: 52A1399A0DF4609
    Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 00000000755293
    Shop #: WSC 00000 000 00000
    VCID: 346D5F0297204E9
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000001
    VCID: 39736E367042B31
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
    Component: Concert3 H06 0350
    Revision: 00000010 Serial number: AUZ5Z6J1469444
    Coding: 050200820104CD00015B870900
    VCID: 458B12C6CCBAC71
    Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
    Component: Display
    2 Faults Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 48
    Reset counter: 231
    Mileage: 42841 km
    Time Indication: 0
    Date: 2012.06.22
    Time: 20:16:28
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 10000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 216
    Mileage: 42841 km
    Time Indication: 0
    Date: 2012.06.22
    Time: 20:16:31
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1401
    Coding: 010C02224001450005
    VCID: 56A9C58A211C7C9
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H06 1401
    Address 77: Telephone
    Cannot be reached
    End ---------------------------------------------------------------------
    Please can somebody advise on how I can get this to work? Many thanks
