Bluetooth location
rizzini7 May 5, 2013
  1. rizzini7
    rizzini7 Active Member VCDS Map User
    951
    146
    43
    Been looking at an rnse unit. The seller says it has working Bluetooth and is saying its built in as he can't find a module, where's the Bluetooth module located on a factory fitted unit so I can get him to check? I thought the bluetooth is separate from the rnse.
    Thank you
  2. ben.w93
    ben.w93 Member
    213
    22
    Bluetooth is separate from the RNSE unit, I believe the module is located under the passenger seat. It could be that it it just coded to have a bluetooth module. I hope that is of some help.
  3. rizzini7
    951
    146
    43
    Cheers mate I'll tell him. He's been using the Bluetooth so there must be a module
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    He doesn't know what he's talking about.
    Bluetooth is a separate module which is factory mounted underneath one of the front seats (which is probably why he can't find it).
  5. ricostuart
    ricostuart Active Member
    409
    43
  6. rizzini7
    951
    146
    43
    I was right then, thought I was loosing the plot
