Bluetooth interference/background noise
Jimmy mac Jan 13, 2013
  1. Jimmy mac
    Jimmy mac New Member
    Hi All
    New to the forum, this is my first post so hope it's in the correct place. I have recently retrofitted RNSE, MFSW and bluetooth (genuine audi parts) to my 2007 2.0 sline dsg A3. Everything working fine however background noise for telephone call recipients at speeds of even 30mph is terrible (got the wife to drive the car and call me). Everything was brand new and no cables were damaged when installing. Not sure what to try now, is this noise to be expected. I have never had this level of background noise on any of my aftermarket handsfree kits.
    Thanks in advance.
  2. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    602
    57
    Genuine vw/audi mic in the light cluster? What loom did you use - kufatec?
  3. Jimmy mac
    Hi Phil used genuine vw/audi mic with genuine harness, installed in light cluster. Could it be incorrect coding, if you mute the mic through the rnse the noise stops as stupid as that may sound does that rule out interference?
  4. phil_w
    602
    57
    If its definitely not background hiss but rather car / wind noise I would double check the placement of the mic - maybe do a test with the mic dangling out of the cluster to see what the difference is?
    Everyone I've fitted has just worked apart from one where the mic was faulty ( but it didn't work at all)
  5. Jimmy mac
    Thanks, if its background hiss is there something in particular you would change, ammend or replace? I will take a drive today with the mic dangling as suggested.
  6. phil_w
    602
    57
    Depending on where the mic came from might be a light chance the wires are the wrong way round from the mic? Probably not though..,
  7. phil_w
    602
    57
    Make that 'slight chance' :)
  8. phil_w
    602
    57
    Worth checking part numbers too - can you list them here of all the bits?
  9. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,764
    661
  10. Jimmy mac
    Here is the eBay item I purchased, I placed unit behind/under glovebox, it would appear harness is not genuine audi then. At standstill no noise at all, it appears then that mic is too sensitive. The wire was routed behind dash up pillar to light cluster. I have tried swapping wires with no success, when you do this you can not be heard at all.
    Audi A2/A3/A4/A6/TT Genuine Bluetooth | eBay
  11. Jimmy mac
    I purchased Ebay item:
    i have tried swapping mic wires it does nothing it all. There is no interference noise at standstill, just awful at 30 -70 mph. I can be heard clearly but the background noise is shocking, could the mic be over sensitive? Can this be adjusted. I had a drive with mic hanging down no improvement.
  12. Jonse
    Jonse Active Member
    448
    49
    I there mate, I had this aswell but i have the kuftec one. People had said they i had background interference but then i adjusted the volume of the mic, which has no solved that. I adjusted it by calling a number through the RNSE. I dont know if this is just to adjust for the kuftec kit all off kits.
  13. B5NUT
    3,764
    661
    The module & microphone are genuine but the wiring harness is not, also the BT antenna looks rubbish and could be causing problems this is the genuine item
    You may want to check the adaptation setting as the sensitivity my have been turned up.
    A131,0,Microphone Sensitivity
    A131,5,Microphone Sensitivity
    A131,6,Microphone Sensitivity Adjustment
    A131,7,Range: -6...+6 dB
    A131,8,
    A131,9,0 = ±0 dB / 1 = +1 dB / 2 = +2 dB
    A131,10,3 = +3 dB / 4 = +4 dB / 5 = +5 dB / 6 = +6 dB
    A131,11,128 = -1 dB / 129 = -2 dB / 130 = -3 dB
    A131,12,131 = -4 dB / 132 = -5 dB / 133 = -6 dB
  14. Jimmy mac
    Ok I have checked the setting the microphone sensitivity is set at 0. Changing it to 5 seems to reduce road noise are there optimum settings for this?
  15. phil_w
    602
    57
    Sorry bit late replying - but yes everything looks ok but he bluetooth antenna definitely not oem. Hopefully the sensitivity tweaks will cure....
