Bluetooth Help
chasdrury Nov 28, 2013
  1. chasdrury
    chasdrury Member
    362
    17
    Hi
    My bluetooth has started to not work - I can't find the bluetooth from the phone - the screen on the RNSe says "Your phone is not connected or attached properly". I have tried to search when the ignition has just been switched and still nothing. Could it be a coding issue? I had to have a new central convenience module recently becuase it died!
    Chas
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Could be a fult code stored on the BT module - some of them cause it to turn off the BT signal.
    Check address #77 using VCDS.
  3. chasdrury
    chasdrury Member
    362
    17
    Thanks, now to find VCDS in Leeds!
  4. ilknur07
    ilknur07 Member
    33
    Dear all,
    Recently I bought RNSE unit and BT (Harman) Bluetooth module and installed them to My seat exeo 2012 which is based on Audi a4/b7
    I changed adaptation channel 62 in the instrument cluster to 23. Now Bluetooth is working, sometimes signal broken. It disconnect and reconnect itself .
    It is impossible to go 77 Telephone module to do coding. VCDS says that :
    1. While doing auto scan
    Address 77 Telephone Labels:None
    VCID: 55AB9F8DBF1A771
    Note: Excessive Comm Errors
    2. When individual go to 77 Telephone
    Too Many Comm Errors
    Thanks many
    Any help would be appreciated.
    ilkure
