Bluetooth Gremlins
trims Dec 4, 2007
  1. trims
    trims Member
    66
    My Nokia Series 40 phone (Nokia 6300) has hooked up faultlessly to my Audi Bluetooth phone prep - up until now.
    When I start the car the phone hooks up via Bluetooth for a few seconds, then disconnects. A minute or so later it hooks up again for a few seconds, then disconnects. Repeat . . . . :think:
    Has anyone here had the same experience? What's the remedy?
    I've reset to factory settings, restablished the Bluetooth connection, and I'm now waiting to see if the phonebook will reload - but that does seem to take an age via Bluetooth (I don't have a cradle). I'll let you know if this reset works, eventually.
    I've searched the forums and haven't come across this problem before: please bear with me if this has been posted previously.
    Any offers??
  2. daviscup
    daviscup Member
    134
    Mine plays up as well. When I get into the car it pairs up fine, but when I try to make a call it disconnects the bluetooth and then re-connects after about a minute. Once it does this it will make all subsequent calls without any problems. Weird! My phone is a Sony Ericsson W880i. Bit of a pain but i can live with it I guess.
  3. RGBArgee
    RGBArgee Guest
    I had exactly the same problem with my 07 A6 Sline Avant (Black of course) Nokia 6280 engaged then dropped out, Vodafone sent new Sim card which cured the problem for a while, but rubbish phone. Have now resorted to old 6230 which is fine until I can have a new phone in January 08. Any tips are the 6500 (Black non slding) any good?
    Rick
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    I had the same problem with a Nokia N70.
    It's caused by the rubbish Bluetooth software stack that Nokia use.
    Been 100% reliable with both a SonyEricsson K610i and my current HTC TyTN II.
  5. Spin140
    Spin140 Well-Known Member
    2,196
    186
    I have the nokia 6300 also and suffer intermittent disconnecting, I too am going to revert to my old phone so that I can get a cradle and bypass bluetooth as it gets on my nerves with its 'binging' & 'bonging'.
    The handsfree set up is great in the Audi just a shame no up to date cradles are available :(
  6. trims
    trims Member
    66
    The reset did work - eventually. The phonebook takes an age to load via Bluetooth, but the system seems to be able to do it in several 'sittings'. Will now wait to see how long it is before I get the binging and bonging again . . . . .
  7. donvas
    donvas New Member
    27
    There can be two fault, poss the phone firmwire might need updating or the car phone ecu might need a software update.You can get a lst of phones which Audi have tested and firmwire test on there web site.....
  8. trims
    trims Member
    66
    Many thanks. My Bluetooth stack has gone t**s up again. Bing bong.
    Checking out the Nokia forums reveals this is not an uncommon problem with Nokias. The fix requires a firmware upgrade from my current v 4.71 to v 5 or higher (current version = v 5.50). Requires a cable, which is now on order. Will let you know if this works: I guess there are plenty of members out there with Nokias.
    NB I don't think this fixes the Symbian (N series) phones.
    If this doesn't work I guess I'll be getting a Sony Ericsson next . . .
  9. N8
    17,163
    718
    Link anyone?
  10. trims
    trims Member
    66
  11. trims
    trims Member
    66
    Updated the Nokia 6300 firmware. Not for the faint-hearted. No better.
    Tried the RNS-E / Bluetooth with a Nokia 6310i and Sony Ericsson W810i. Checked compatibility on Audi's german web site:
    http://www.audi.de/etc/medialib/cms4imp/audi2/reports.Par.0094.File.pdf
    Still no better - same fault - constantly dropping Bluetooth connection.
    Asked dealer to check it out whilst in for another job - turns out the Bluetooth ECU may be faulty. Spare part has to be ordered from the Fatherland, so 3 week wait. :crying:
  12. bacardi
    bacardi Active Member
    1,139
    Maybe too late but you don't need a special cable, just use a normal mini usb cable, download the Nokia software updater program from Nokia.com and bob's yer mothers brother etc
    works on all recent Nokia's
  13. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    I had the dropping out problem with numerous Sony Ericssons a while back.
    I can't quite remember the exact solution, but beleive it or not, it was to do with the received/made caller history in the phone.
    Next time you hook up and it disconnects, try clearing the call history of all made/recieved/missed calls. Then re-connect and see what happens......
    I'll have a trawl through some old threads and see if I can find the solution.
  14. sputnik
    sputnik Member
    30
    I had the same problem with the same phone not in my own car (05) but in another A3 (07) that I drive from time to time. I carried out the latest software update on my phone with Nokia and it fixed it. The only difference between my car and the other was mine doesn't have a multi function steering wheel.
  15. trims
    trims Member
    66
    Thanks.
    I had already tried deleting the caller history from the Nokia 6300, but it made no difference.
    The Sony Ericsson W810i I tried was my daughter's Xmas present - which had a blank caller history and only 4 names in the address book. No joy.
    PS Thanks bacardi - you're right - a normal USB cable should do the trick for upgrading the 6300.
