Bluetooth DIS coding
Inertiauk Jun 4, 2012
  1. Inertiauk
    Inertiauk Active Member
    574
    29
    I Retrofitted Bluetooth in my B6 S4 today using the newer 'H' Bluetooth unit, and coded it ad coded my RNSE. Very happy with the results and the coding was fairly easy given all of the info on this forum and others via google.
    i expected that the call information etc would show up on my DIS but it doesn't, it just says 'phone'.
    Is there some coding I need to do on th clocks or something? Or am I just expecting too much?
  2. NHN
    29,333
    1,717
    Did you code the rns-e 37 with comfort XXXX7XX & the BT 77 also as comfort XX1XXXX
  3. Inertiauk
    574
    29
    BT 77 = 0010722
    RNSE 37
    = 0309714
    So yes in Both cases.
    When my phone rings the DIS only says 'Phone' but no other information.
  4. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    Have you coded the Instruments?
    Channel 062: CAN-Databus Infotainment (Installation List)
    +00001 = Radio (Optional)
    +00002 = Telephone (Optional)
    +00004 = Navigation (Optional)
    +00008 = Telematics (Optional)
    +00016 = Intrument Cluster (Standard - only coded with 2nd Component)
  5. NHN
    29,333
    1,717
    Go into instruments & check in adaptation channel & make sure telephone is enabled on the Bus.
    • +00001 = Radio (Optional)
    • +00002 = Telephone (Optional)
    • +00004 = Navigation (Optional)
    • +00008 = Telematics (Optional)
    • +00016 = Intrument Cluster (Standard - only coded with 2nd Component)
  6. Inertiauk
    574
    29
    Will do this, Thanks.
  7. NHN
    29,333
    1,717
    lol, great minds & all :)
  8. Inertiauk
    574
    29
    Left my laptop at work :-/ Thought there was something missing when I sat in the car just now holding my VCDS lead.
    Will do it tomorrow.
  9. AudiLeon
    2,202
    160
    All the stuff that's stuck in my mind from when you helped me install mine lol
  10. Inertiauk
    574
    29
    Changed 062 from 21 to 23 and its working perfect now, thanks guys.
  11. NHN
    29,333
    1,717
    Thats a good thing, glad someone's learning :)
    Great to hear & thanks for reporting back.
