Bluetooth car kit
monty77 Dec 2, 2004
  1. monty77
    monty77 Member
    391
    Who has one in their A/S3? Which one? Easy to fit? I've read somewhere that some of them can somehow interface with the DIS, that true?
    Cheers!
    Adam
  2. I have the nokia CK7 kit - Didn't fit myself - No cradle as I think they look **** the quality is excellent - Paid £150 fitted -
  3. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    This one? http://www.expansys.com/product.asp?code=CK-7W
    Can fit myself easily enough, where did you locate the button? Agreed about the cradle, no need for it in my case either.
    Cheers,
    Adam
  4. I have the Parrot CK3100 fitted to my S4, fitted myself easy job, although most units will not interface with the BOSE so sound does not come through speakers, so had to fit concealed seperate unit, mutes ok though.
    As for interface with DIS, most do, although they only say "Telephone" or more accuratly TELEFON, as this is part of the mute function, when in operation, or a call comes through.
    Really pleased with the Parrot, no cradles phone stays out of sight, although functionality like all things bluetooth depends on the exact phone, good thing about the Parrot is that you can upgrade the operating software via Bluetooth enabled laptop to keep it current with your phone.
    /ubbthreads/images/graemlins/groovy.gif
  5. Cage
    Cage Member
    95
    I also been thinking about getting the Parrot CK3100 as it was a cheaper alternative to the new Nokia 610 car kit.
    [​IMG] Parrot CK3100
  6. S3_MCD
    S3_MCD Member
    389
    fitted the Nokia CK-7W ... £85 from Blueunplugged.com, you need an interface cable if u have got std HU and if so make sure ur order a BOSE specific (or not one) ..cost about £30.
    will take some pics if u wanna see it ...
    easy to install, takes a while if u want to do it well.
    Marcus
  7. S3_MCD
    S3_MCD Member
    389
    [ QUOTE ]
    [/ QUOTE ]
    If proper cables r used they work fine, mines running on internal speakers on BOSE system, mute works fine and DIS says "PHONE" to let u know ur on the phone, when I am /ubbthreads/images/graemlins/wink.gif
  8. PaulRS3
    PaulRS3 Well-Known Member
    1,209
    141
    fitted a SE kit to my S3.
    it comes up "phone" on dis and on sat nav plus when it mutes thats it. Thats the oly itergration your get with the DIS
    fitted straight into my sat nav (with bose) with no interfaces at all.
  9. monty77
    monty77 Member
    391
    Thanks for the replies chaps!
    Not fussed about sound coming through hi-fi or Bose integration as the std stereo is being binned for the stack of Alpine gear sitting at home the moment I get my hands on it...just wanted a reliable kit that doesn't require too much [censored] about. Nokia CK7 seems to fit the bill nicely .. cheers!
    Adam
  10. jediknight
    jediknight Member
    835
    So CAN the nokia CK7 kit link in with the standard bose HU?
    dont want to fit a little speaker in the car to be honest
  11. S3_MCD
    S3_MCD Member
    389
    [ QUOTE ]
    [/ QUOTE ]
    all works fine, u will need to get a AUD02NOK + NOK01ADP (2 kits in one box) which will interface with ur Audi HU.
    31.99 + 2 p&p from Justcarkits.co.uk
  12. RAPS3
    RAPS3 Well-Known Member
    1,142
    135
    So with this kit, I take it you need to turn on the bluetooth on your phone when you get in the car?
    Can you set it up so that it switches on / conects automatically?
    I have the Nokia 6230 at the moment with the Jarbra headset, which works fine, but messing on switching the bluetooth and then the headset on is a pain in the ar#e.
    May treat myself to a new handsfree kit for crimbo.
  13. monty77
    monty77 Member
    391
    [ QUOTE ]
    [/ QUOTE ]
    I have a 6230 too, just leave BT enabled and it'll automatically connect. Doesn't seem to affect battery life too bad.
    Adam
  14. RAPS3
    1,142
    135
    I thought leaving the bluetooth enabled eat the battery.
    I'll give it a try.
  15. S3_MCD
    S3_MCD Member
    389
    leaving BT enabled decreases battery life of phone, but not so much as u would notice.
    the lead prvides the mute, function, connection ro internalal speakers and separate ignition feed to turn it on/off.
    very pleased with it /ubbthreads/images/graemlins/smile.gif
  16. jediknight
    jediknight Member
    835
    so where do you get the ignition feed again? just from the fuse box?
    im planning on buying and fitting myself. is it pretty easy? those cables just look like the plug into the existing loom??
    cheers
  17. RacingTeatray
    RacingTeatray Freezing in Moscow
    249
    I have a Sony Ericsson HCD-30 system in my car and it works perfectly even though I now have a Motorola phone. As has been mentioned, you just leave the bluetooth enabled and it automatically links when you turn the ignition on. Was I think around £150 fitted from memory.
    And yes it automatically mutes to read "Telefon" in the DIS.
  18. Jlovett
    Jlovett New Member
    21
    Hi just curious to know which cables these are? I got the display in and the mic up then found out It wouldn't connect.If you could point in the direction of the right cables that would be great! I got a a3 55 plate with the bose sound system.
