Bluetooth added - Working but a few issues.
AudiLeon May 4, 2011
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,170
    150
    I hope someone can offer some advice on this.
    I've installed the bluetooth on my car, I have a RNS-E with the latest software installed.
    The satnav sees the bluetooth, i can make calls and it's all fine.
    I have a few issues though, I have a MFSW and when I press the left button to scroll through the numbers, it's on a limited time. After about 3 seconds of scrolling it goes off.
    Also, I cannot enter 77 on vcds. It says no controller installed. Any advice welcome.
    No fault codes showing on the rns-e either.
  2. s8craig
    1,745
    53
    If you cannot enter module 77 on an A4 it is because your K-line is not connected correctly or you have not installed a genuine Audi unit.
  3. AudiLeon
    2,170
    150
    If Kline wasn't connected properly, would it work right?
  4. s8craig
    1,745
    53
    Yes it would work, k-line is just for diagnosis.
  5. AudiLeon
    2,170
    150
    Excellent, I'll go out and double check it all.
    Cheers Craig.
  6. AudiLeon
    2,170
    150
    Turned out I had the Kline on the wrong wire. Oops!
    So I can log into it now.
    All is fine, but the time it gives you to scroll through the numbers is still really low.
  7. AudiLeon
    2,170
    150
    Any ideas on this ladies and gents? I'm sure it's just a coding issue somewhere.
  8. s8craig
    1,745
    53
    There is no coding for that
    The BT module should be 0011822 for an A4 with RNS-E and MFSW
    The RNS-E should be 00xxx7xx
    The cluster adaptation channel 62 should be 23
    The steerring wheel should be 04xxx
  9. AudiLeon
    2,170
    150
    hmm, seems right then Craig. Oddness!
