Bluefin superchips stage 1 remap - honest review
sliced Dec 27, 2013
  1. sliced
    sliced Drive safe, stay alive.
    1,562
    334
    update: no reply since that brief call, dissapointed, typical sales manager...
  2. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    Man all they want is your money end of. :think:
    ACWKGYTO likes this.
  3. wuta3
    wuta3 Well-Known Member
    1,129
    347
    ****, hope you get it sorted sliced :)
  4. Marshy
    Marshy Settled in Audi RS3
    1,352
    469
    Think I'd be ringing him back on his house phone just to make sure he does something.
  5. Cockney Boy
    Cockney Boy Member
    483
    Shorting out a battery is not only stupid but dangerous!!!!!
  6. Marshy
    1,352
    469
    Don't think they meant shorting the battery out.
    If you remove the negative terminal and touch that lead to the positive lead it drains all the power from the capacitors in the ecu so erasing learnt information.
    No harm can be caused because with the terminal removed from the battery there's no circuit made.
  7. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,676
    2,572
    You don't short out the battery read the post, You remove a lead from the battery the negative is good and then short that negative lead to the positive on the battery. This will remove any residual charge from the modules that is stored in capacitors etc.
    Any plank that shorts the battery has no right to be under the bonnet in the first place.
    This will not damage any modules. Or I wouldn't have suggested it.
    On some cars you will need to reprogram stations on the radio or enter a code.
  8. desertstorm
    5,676
    2,572
    Thank you beat me too it
    Karl.
  9. Artimus
    Artimus Shortback
    2,016
    485
    you would still need to remove both battery terminals or you'll blow something by shorting the battery to earth.
  10. Cockney Boy
    Cockney Boy Member
    483
    In post #39 you clearly state to short the terminals together
    If a few of us mis read that statement then so will others!
  11. Marshy
    1,352
    469
    No if the negative terminal is removed the battery isn't connected to earth.
    All your really doing is joining the cars circuits together without the battery so there's no power to do any damage.
  12. Alex_007
    Alex_007 Member
    294
    You'll always find a story or someone not happy with any well known reputable mapper , the best of the best make mistakes , as long as they rectify it with compo then all good.
    Artimus likes this.
  13. Marshy
    1,352
    469
    Yeah pretty much bang on.
    If they rectify the problem and pay some kind of compo I'd be happy as long as the car drives well.
    Alex_007 likes this.
  14. Artimus
    Artimus Shortback
    2,016
    485
    Doing that makes the whole car live & it can easily short to earth through anything that touches it ...including a person.
  15. Cockney Boy
    Cockney Boy Member
    483
    Have you ever seen a capacitor blow? They like to go pop and typically take out other components in the process.
  16. Marshy
    1,352
    469
    I'm not sure where this is going and obviously not helping poor Sliced.
    But for one last time for anyone who doesn't understand.
    The battery gives power but only when the positive and negative terminals of the battery are joined together.
    With one terminal disconnected its like the battery isn't there as it's not in the circuit so NO damage can be done.
    I didn't suggest this but agree 100% that no harm will happen to the cars circuits.
    Anyone who doesn't believe this or has their own ideas on this, please don't do it.
    Can we please get back to poor Sliced original thread.
    Alex_007 and sliced like this.
  17. sliced
    1,562
    334
    Inertiauk and ~RS~ like this.
  18. Alex_007
    Alex_007 Member
    294
    Hahaha quality I'm gonna try that move on my mrs later
  19. hollow
    hollow Well-Known Member
    1,404
    162
    do you have vcds ? if so see if you can connect to the engine ecu and copy down the hardware software numbers at the top . that way i could send you an original map for your car so you can load that . saying that ecu may have to be put into boot mode for flash to work ,worse that that bdm may be the only way to resurect your ecu .
    not trying to make you feel worse but if you have lost all comms with the ecu then the file they sent was either really bad or the checksumm was incorrect
  20. Viking
    Viking Bloody Viking...
    226
    20
    Careful when mucking about with batteries. As said, if you're unsure, don't do it.
    Or....
    ...bad stuff can happen.
    Artimus likes this.
  21. desertstorm
    5,676
    2,572
    I said
    "Try disconnecting the battery earth lead and short to the positive for 30 seconds to see if that helps."
    If somebody takes that as short the battery out then as I said they shouldn't be messing under the bonnet in the first place. The 2 cars burnt out when people tried to jump start them is again another example of somebody who didn't know what they were doing and shouldn't be under the bonnet of a car. I try to provide helpful solutions to peoples issues and problems. I assume they have a bit of basic common sense but I see on some forums that may not be the case.
    For the record I have a HND in electrical / electronic engineering. I worked at Lucas Engine management systems for several years on fuel injection units, Trip computers , dashboards etc. I have been playing with cars for over 30 years so maybe sometimes I should try and explain in very simple terms for the avoidance of doubt.
    And I have seen lots of capacitors when they have blown up , I have fixed plenty of switch mode power supplies in my time.
    I will say no more I hope you get the car sorted.
    Karl.
  22. fireheed
    fireheed Member
    34
    Hope you get it sorted.
    I'm sure the module keeps the original ecu file to put back to standard if needed. But that's no use to you as the cars not recognising the Bluefin.
    Don't discount the Bluefin as I've got it on my S3 and it has been fine, I'm very happy with it.
    sliced likes this.
  23. sliced
    1,562
    334
    good news, MD got an employee to go in and managed to get my ecu back to original stock map. Feels slow, but suppose its better than nothing. Hopefully they are going to sort me out with a new map sometime at the end of next week when they re-open.
    voorhees, Artimus and bobmatt like this.
  24. Marshy
    1,352
    469
    At least that's something mate.
    Keeps you mobile until they sort you out.
  25. fireheed
    fireheed Member
    34
    Nice one glad to hear the cars going again.
  26. Alex_007
    Alex_007 Member
    294
    Get some money back.
  27. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,217
    2,032
  28. Alex_007
    Alex_007 Member
    294
    Haha
  29. Marshy
    1,352
    469
    Yeah with the 20% sale on just now too.
    Or 35% off if moving from another tuner so £390 for Revo!!!!
    Bargain
    sliced likes this.
  30. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    885
    £390..........Thats expensive..........lol. 10% discount off Shark remaps from me for ASN members. Musn't Grumble!!!!
  31. Marshy
    1,352
    469
    You quoted me £400😒
    RedDejavu and Alex_007 like this.
  32. Dean_T
    Dean_T Active Member
    645
    139
    43
    Great news, now go use a company that will load a map and test it for you to make sure its 100% ok :)
    I have always been of a mind, where a map of a car is concerned - don't do it cheaply, get it done by specialists in the field.
  33. Artimus
    Artimus Shortback
    2,016
    485
    Superchips in Milton Keynes will load it, RR it too, probably FOC after these shenanigans I'd have thought.
    voorhees and sliced like this.
  34. sliced
    1,562
    334
    The files department have sent me a new map, seems much better having a mapped car now again.
    However now two thing ive noticed, a strange squealing noise and the car gave like a tin can rattling noise from the engine when parking up! will have to investigate this further
  35. Alex_007
    Alex_007 Member
    294
    And this has only happened since putting a new map on?
  36. sliced
    1,562
    334
    yep did email them but no response yet...
  37. Alex_007
    Alex_007 Member
    294
    Did you have car checked for any codes before it was fitted?
  38. Artimus
    Artimus Shortback
    2,016
    485
    I'd personally dispense with the e-mails, call them & direct them to this thread, as they're not exactly covering themselves with Glory. :(
    Contact:
    Superchips Limited Head Office
    Buckingham Industrial Park
    Buckingham MK18 1XJ
    Open weekdays 8.00am-5.00pm
    +44 (0) 1280 816781
    Can't you reload the original map or drive up to Superchips with the current map & have them load a decent one there?
    I'd email you a copy of my original file, but a: I wouldn't know how to get it off the handheld, & b: I'm not certain the if immobiliser code would be included & render your car useless again.
  39. sliced
    1,562
    334
    Cheers, gave them a ring, and they said that my email was the next thing they were going to reply to.... how convenient lol. looking like i might just have to make a complaint!
    Artimus likes this.
  40. Artimus
    Artimus Shortback
    2,016
    485
    you know ...thinking about it, I seem to remember a tinny rattle from my car when I originally loaded the map, but it didn't last more than 30 seconds or so and I thought it must have been down to timing changes taking place before Auto ECU adjustments caught up.
    Is yours doing it constantly on idle now you've driven it a few miles with the new map, or has it stopped?
    sliced likes this.
