Blue/white smoke
steady jay Sep 8, 2012
  1. steady jay
    steady jay Member
    184
    This f**king car is begging to annoy me now.
    Just finished work started the car up fine no problem. Go to pull away on the main road and filled it with blue/white smoke. Hasn't done it since.
  2. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro s tronic saloon
    1,511
    386
    Checked your EGR valve lately? Could be sticking open/closed.
  3. steady jay
    steady jay Member
    184
    Should've mentioned its 1999 1.8t
  4. Bradderz_1988
    3,947
    235
    White smoke is normally coolant/oil related and blue tends to be more fuel related ?? possibly just leaky valve stem seals !
  5. aragorn
    18,157
    766
    had it been idling for a long time?
    Could be valve stem seals if so.
  6. steady jay
    steady jay Member
    184
    Yeah was waiting for a mate to walk out of work too so probably 5-10 minutes, what options do I have to sort the stem seals?
    Cheers jay
  7. steady jay
    steady jay Member
    184
    Little update/research it hasn't kicked out any smoke since last Saturday been told to check under oil cap while it's running for excess pressure and it has a lot of pressure. Which could hopefully rule out stem seals? And possibly something much easier.
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    really?
    Blue - Oil
    white - Water/Steam
    Black - Fuel (i.e too much of it)
    at least that is what I always went by
  9. jcb
    4,132
    13
    I am no AA mechanic but you have to ask yourself where that pressure is coming from?
    usually pressurised header tank and smokey exhaust is an immediate check for head gasket trouble.
    overheated recently, run low on coolant?
  10. steady jay
    steady jay Member
    184
    Nope not overheated once, coolant is fine too. As it hasn't done it before or after that 1 occasion it's hard to pinpoint so unless it happens again I'm not going to worry too much.
    I'll try to get my hands on vagcom and see if that comes up with anything.
  11. Bradderz_1988
    3,947
    235
    Get a sniff test on tge coolant bottle to check for hydracarbons this will be an indication of the head gasket.
  12. Turbo unit
    Turbo unit Member
    93
    possible slighty worn turbo seals! Happend to my s4 blue/white smoke didnt do it again for a few weeks then 1 completely just gave up this was a bout a year ago and they had done over 100k so due a change any way
