Blue tooth retro fit
Phil-1 Dec 19, 2013
  1. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,027
    672
    Sorry I know this has been covered lots of times, but I'm getting very confused.
    I have just got myself a used BT module for my A3 8p MY09 SB S-Line.
    What I'm confused about is the plug and play wiring harness, I have seen loads all different and costing from £12 to £25. I know I will also need the mic, but after doing a search and giving the part number to my local dealer I was told it's the wrong number. So what I really need is the following.
    Link to the correct wiring harness and Part number/link for the Mic
    I know it will need coding so will be looking for someone local with the knowledge.
    Thanks in advance
    Phil
  2. s3ollie
    s3ollie Member
    762
    Hi, this is the one on eBay you need 180737531631 may not be the cheapest but is the right one and the 1st one that came up
  3. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    As Ollie said, the Carsystems looms are great, I use them for all of my retrofits.
    I'd definitely buy through their website though, its in EUR on their website and you'll get a better conversion rate.
    Wiring - Audi Bluetooth Plug&Play Wiring - 220cm - I'd definitely go for the 220cm length, then you can install it in its OEM position under the passenger seat.
    Microphone - Audi Mic - Bluetooth / SDS - 8L1862373A
    Even I know how to solder the connections, I'd still always get the plug&play solution, much cleaner install and saves a lot of time, and also allows you to easily remove to sell on if you need to at a later date.
    Good luck!
    Phil-1 likes this.
  4. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    a6_chris likes this.
  5. jb0o
    2,664
    118
    Yup, Chris is a good guy; knows his stuff.
    a6_chris and RobbieWebs like this.
  6. Phil-1
    2,027
    672
    Thanks guys. I have made a note of the links and will buy the bits once the module turns up.
    The OME the module goes under the passenger seat. Is this just as easy as mounting it under the dash? What other bits would I need?
    Thanks Phil
  7. RobbieWebs
    1,031
    249
    Going by A6Chris guide the plug and play cables he got weren't long enough to put it under the seat.
    I'd deffo put it under the seat if I was doing it, saves putting the unit in the dash :)
  8. Phil-1
    2,027
    672
    To put it under the seat ( I want it as much like genuine as possible) do I need a bracket or does it just sit in something?
  9. Andy1608
    Andy1608 Active Member
    615
    204
    43
    I replaced mine in an old a3 2008 and there was a black plastic box for it to sit in under the passenger seat
  10. Phil-1
    2,027
    672
    Did you have to remove the seat to do it? Can you see if the box is there without taking the seat.
  11. Andy1608
    615
    204
    43
    Yeah had to remove the seat .You have to pull the carpet back to get under too it so I'd say no you can't see without removing it unless you want to add a viewing window to your carpet lol
    Phil-1 likes this.
  12. Phil-1
    2,027
    672
    A job for after Christmas ;-)
  13. Phil-1
    2,027
    672
    Just about to order the bits. Is this the mic that fits in the light? The cable look very short.
  14. Phil-1
    2,027
    672
    I have ordered the bits, so once they arrive and we have some nice weather I will get them fitted.
  15. Andy1608
    615
    204
    43
    Waiting for nice weather Phil, could be a while lol
  16. Phil-1
    2,027
    672
    I think your right. Might have to find a friendly farmer with a barn.
    Thinking I might wait and do the footwell lights at the same time and interior light
  17. Andy1608
    615
    204
    43
    We aren't short of friendly farmers us Yorkshire folk lol
  18. Phil-1
    2,027
    672
    I have a friend that's a farmer, they have a heated workshop I have been told I can use.
    And they have tea and biscuits 👍👍
  19. Andy1608
    615
    204
    43
    Ha ha I'm trying to think of a thread that doesn't involve you and biscuits lol
  20. Phil-1
    2,027
    672
    I'm hoping the misses is getting me a packet or two for Christmas ;-)
  21. hollow
    hollow Well-Known Member
    1,404
    162
    if you havent already ordered and have the rnse head unit you might as well order the sds+bluetooth wiring and enable the sds on your rnse .
  22. Phil-1
    2,027
    672
    I don't have RNS-E yet, hopefully next year some time.
    I have ordered the wiring loom as recommended, should be here in the new year or earlier.
  23. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Correct, the loom I got wasn't long enough otherwise I would've put it below the seat.
    I didn't know you could get the longer P+P loom but just seen Jonny posted it up so might do this in time.
    There are no issues having it where it's currently at, no rattles etc.
  24. Phil-1
    2,027
    672
    Once the harness arrives I will see if it's going to be long enough to fit under the seat.
    Will get some photos when I'm doing it 👍
