Blowing fuse 14 (Interior lights + Central locking) Ideas?
Markb Feb 4, 2006
  1. Markb
    Markb Active Member
    2,139
    Any ideas to why my car keeps on blowing fuse 14, which is the Interior lights + Central locking? As soon as I put a new 10AMP fuse in, it blows /ubbthreads/images/graemlins/confused.gif
    Although my Clifford alarm is still locking the doors fine. So I don't think it's the central locking as such, but then again I've got no door locks if that will make any difference?
    Any ideas to how I can solve / test it will be great.
    Mark.
  2. Markb
    Markb Active Member
    2,139
    Up we go.
  3. Markb
    Markb Active Member
    2,139
    TTT
    Annoying me now, even though it is not effecting anything with the central locking it means that I've got no interior lights.
    Anyone got VAG Com in the Midlands? Or got any suggestions?
  4. HTC
    HTC Active Member
    3,428
    9
    Sounds like you have a wire going to ground.
    Get a test light or multimeter on the fuse contatcs. One should be +12v and the other should be nothing. If the other or both are showing an earth, then you need to trace the wire. It may have been damaged and touching bodywork.
    Either that or its back feeding via the after market alarm connections. You may need to fit some 12v diode to isolate the clifford alarm.
  5. Markb
    Markb Active Member
    2,139
    That's what I was thinking /ubbthreads/images/graemlins/frown.gif Going to be a pain to find though.
    Will the VAG Com not show up a fault code for it? Maybe eliminate some things?
  6. HTC
    HTC Active Member
    3,428
    9
    It wouldn't hurt to give it a go, but if the control module is disconnected, thats all it will tell you or it won't be able to communicate.
