Blow me. . .
Olly_K Nov 11, 2006
  1. Olly_K
    Olly_K Administrator
    2,678
    Or blow out, it would seem, this is what happened to me at 140 on thursday night :
  2. Ess_Three
    Ess_Three Active Member
    5,383
    Ouch!
    Lucky boy...
    I'd expect the ESP to have done it's stuff?
  3. Olly_K
    2,678
    no it was off, but it was a rear and the 4wd helped it stay straight so it look worse than it was, i just cant out why there are 2 holes ?
  4. treblesykes
    treblesykes Member
    690
    1:40 am or 140mph?
  5. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    Damn, how the hell does that happen? Good to see you're ok :beerchug:
  6. scoTTy
    scoTTy Active Member
    1,962
    I take it that you'll get the tyre looked at?
  7. rickparmar
    rickparmar Active Member
    2,312
    12
    ouch, glad your ok mate
  8. L1 HCS
    L1 HCS Active Member
    4,600
    :sign_omg:!!!!!!!
  9. james0808
    james0808 Active Member
    3,548
    I would of shat my pants.Glad to see no other damage to you or the car.
  10. Olly_K
    2,678
    You mean back to goodyear ?
    I think I've worked out what happened, the smaller hole is actually what caused it, the massive "gap" in the sidewall is probably due to running flat at 140mph
  11. ARCHIE
    ARCHIE New Member
    12
    Hi,
    Just thought i,d add my 2p worth,
    I know nothing about tyres but i,m pretty much over qualified when it comes to things going bang.................
    The small hole for my money was caused by the slack in the tyres band at speed and under load, nipping the rim as the belt shifted thus cutting the tyre, there has been no rapid escape of forced air at this point !
    The blast happened at the larger hole, see the deposits around the inner rim where the air escaped, the hole would not have been this big initially however the flapping effect of the shredding would have torn a larger hole and there should be thinning of the tyre wall from the inside out, marginally, and not overly so but you will be able to see the shamfered edge ?
    Glad to see you are ok by the way,
  12. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    F F Sake - Lucky boy!!
    If that was on the front at that sort of speed it could have been very messy indeed......
    Doesn't bear thinking about really!
    Glad you are OK :thumbsup:
  13. Adams3
    Adams3 Member
    425
    Glad you are ok, do you think the tyre was damaged at all before this happened??
    Im assuming it must have been!!
  14. raymie
    raymie 6 pot AP
    708
    :wtf: lucky u m8
  15. alexc
    alexc Member
    Lucky it was on the back, easier to control!
  16. ZeroK66
    ZeroK66 Member
    256
    Ouch, indeed thank gawd all is well and you can tell the story. Lucky it was a rear blow out!
