Bloody wheel bolts
gaz71 Sep 19, 2010
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    Just went to fit new wheels and the fronts are locked tight.
    The new bolts are angled fitment and 27mm thread.
    Back wheels rotate ok.
    Any ideas why the fronts are locked up while the backs are fine?
    What would be the best solution - use old bolts, shorter bolts, cut bolts to length or 5mm spacers?
    The new bolts appear to be about 5mm longer than the originals (radius fitment)
  2. Robbo1144
    Robbo1144 Faster in reverse
    70
    i had the same problem when i fitted longer bolts. the only options are put a nut on them and cut them down. or get shorter ones
    Robbo
  3. gaz71
    286
  4. Robbo1144
    70
    yeah they should solve your problem, but the cheaper option is to cut your bolts down, or use the old ones
    Robbo
  5. gaz71
    286
    Was thinking of using old ones but they a radius fitment and the new ones (and wheels) are angled. Surely the bolts should match the wheels for a tight fit?
    Not sure about cutting bolts down, don't want to risk threading the hubs if I don't get it just right
  6. aragorn
    18,611
    871
    I'd cut em down.
    Spacers are just a bodge, and its the wrong fix for your problem.
  7. andybnwc
    andybnwc Member
    752
    as above chop them but yes radius-radius and pitch-pitch
  8. gaz71
    286
    Right, now where did I put my hacksaw :uhm:
