Bloody brake switch issues again !
S3 Paul Oct 16, 2013
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    About 3 months ago my euro car parts bought brake light switch apparently went faulty... Vag com brought up the code of 00526 brake light switch f 27 00. Implausible signal.
    i was told it was because the switch was no gen...
    so I replaced it with one from the dealers,
    well the code is back again... Same fault again,
    could it be something else?
    or can they fail this fast?.
  2. Andrew@A.L.D
    3,873
    609
    Could be the plug on the switch or the wires to the plug
  3. S3 Paul
    2,823
    107
    The fault isn't there all the time and once cleared can take months to come back or... Days
  4. Gops
    3,197
    666
    Comes with a guarantee? Ring the dealers and find out, I'm sure it comes with a guarantee, so they'll replace it.
  5. Tovs
    Tovs Member
    168
    56
    You've replaces the switch, as said on previous post, have you check the wiring? This fault woing come up all the time, it'll show as and when it wants too.
    Also check, measuring value block, did you check this after replacing the switch? Can be that.
    Though I would of thought best bet was to check wires to and from the brake light switch.
  6. S3 Paul
    2,823
    107
    everything looked fine but that was a visual check,
    I remember that was a vag com check to see if the switch makes and brakes the signal... i think i tried that before and it was ok... but ive forgotten what is was.
    The last time i had problems with the car popping a brake light bulb all the time... turned out the switch was the cause.
    I was told this will hinder performance as the ecu will not let me have full power as it thinks the brake pedal maybe down a little??
  7. Tovs
    Tovs Member
    168
    56
    Don't think you'll lose power, not to sure about that. Though as you know its just irritating. It may be a faulty switch again, go to a different garage, get it checked maybe? As said before too, check, the wiring too, from start to finish to and from the switch, I'm sure you may find the problem. Hopefully you can sort it :)
  8. Andrew@A.L.D
    3,873
    609
    The brake switch will kill power to the Haldex not the engine that i know of?
  9. Westy
    Westy Well-Known Member
    17,443
    1,103
    Have you checked your brake lights? I had this exact same issue so I bought a new switch only to have the same problem again. Turned out that the bulb had blown on the brake light bit only. The tail light and brake light are in the same bulb. Worth a try.
