[Blog] Dan-Jnr - 2002 Audi S3 8l (225) Negaro Blue
Dan-Jnr Jun 22, 2011
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Love the RNS-E Dan, that's one upgrade I may leave till last unless I can get one for a good price.
    ...Have you done the Ambient Lights mod?
  2. feck_on_a_stick
    feck_on_a_stick Active Member Team Nogaro Blue
    191
    66
    Thanks mate, that would be awesome! :)
  3. brasiliangringo
    brasiliangringo Member
    626
    10
    My favorite interior colour - looks peachy.
  4. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    Did a power run this evening with VCDS and managed a Mass Air Flow figure of 219 g/s which equates to 273 BHP.
    This is with Revo Stage 1, Badger 5 TIP, Jetex Filter, and standard DV.
    I will do some more detailed power runs at the weekend.
  5. Westy
    Westy Well-Known Member
    17,443
    1,105
    What psi boost was this at Dan? I'm only asking because I also did some logging tonight. I was getting 230g/s (287bhp) at 20psi and 25psi so I think 230g/s is about the maximum a K04 turbo will flow.
  6. Dan-Jnr
    1,234
    386
    Gave the car a quick wash and wax on Tuesday. Resulting in some pretty decent water beading this morning. Which has now become my phones home picture.
  7. Schlaag
    Schlaag Bwah
    486
    32
    Love it!
  8. Dan-Jnr
    1,234
    386
    The aerial gasket had perished so time for a replacement.
    £3.65 from eBay, and took less than 10 mins to replace.
  9. Dan-Jnr
    1,234
    386
    Recent work completed at the very professional and helpful VAG Technik after having an interim service at Audi:
    O/S/F CV Boot
    Front drop links
    Rear ARB
    The S3 has also just clicked 113000 miles.
    For a bargain price of £67.50 I recently purchased a Revo SPS from eBay so I can have a tinker with the Revo map settings.
  10. Dan-Jnr
    1,234
    386
    Removed the Badger 5 TIP and Jetex filter and replaced with the stock TIP and an ITG filter to stop my turbo spiking.
    This is due to the Revo Stage 1 map being too aggressive for a larger TIP.
    I'll save these parts for when I decide to go Stage 2.
    Last weekend gave the car a 6 hour detail.
    Meguairs Ultimate Wash and Wax
    Meguiars Clay
    Meguiars Step 1 Paint Cleaner using G220 V2
    Poorboys Black Hole Glaze using G220 V2
    Poorboys EP Sealant using G220 V2
    Poorboys Natty Wax applied by hand with microfibre pad
    Not long after it rained which resulted in the following photo being taken
  11. Dan-Jnr
    1,234
    386
    Got myself a set of Brembo GT calipers and 323mm discs to improve my braking.
    The difference these bad boys make when braking hard is remarkable.
  12. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    Good to see ur not skimping on tyres either ;-)
  13. Dan-Jnr
    1,234
    386
    Need a set of rears soon. Eek.
  14. Dan-Jnr
    1,234
    386
    A sneak peak at what's to come... Stage 2
  15. Dan-Jnr
    1,234
    386
    Some new purchases ready for an up and coming upgrade
    Badger 5 heat shield for the Jetex Filter, this decreases air intake temperatures especially on full boost as it stops the filter sucking in the warm air round the engine. It also seals against the underneath of the bonnet.
    Set of Eibach lowering springs, 25mm front and 20mm at the rear. This should make the car sit just above the top of the tyres without ruining the handling or ride quality.
    Old piece of hose that needed replacing
    New hose to replace the one above
    Replaced this pair of hoses as the larger one hard perished and kept blowing off the DV.
  16. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Lovely. Standard shocks?
  17. burns3
    burns3 Member
    224
    17
    So what's the difference with nogaro blue and your negaro blue? Is yours a bit darker :D
  18. AVLO
    AVLO Active Member
    295
    52
    what size wheels are you running on Dan-jnr? good post so far i will be starting one on my white s3 in the new year :-D
  19. Dan-Jnr
    1,234
    386
    JD09 - standard shocks for now.
    burns3 - spelt it incorrectly to be different ;)
    AVLO - standard 17inch Avus alloys.
  20. .Ben.
    .Ben. Member
    118
  21. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    I've just read through the whole thread. People who know me will now be like "WFT?!" because I hate S3's more than anything.
    However.
    **** me yours is lovely! What a tidy example with some brilliant mods; I'm really really impressed.
    Dare I say it, this is the first S3 I've ever seen that I would be proud to own. So congratulations and keep up the good work!
  22. Dan-Jnr
    1,234
    386
    Thanks 16Klappe appreciate the comments.
  23. .Ben.
    .Ben. Member
    118
    What did you ask for at the dealer to get this hose? Mine's in similar shape to your old one...
  24. Eddie S3
    Eddie S3 Member
    128
    9
    06A 103 817 D
    I asked him this morning as mine had gone the same aswel :)
  25. Dan-Jnr
    1,234
    386
    Recently had quite a bit of work done.
    Pair of Goodyear Eagle F1 for the rear
    Coolant topped up as it showing low when parked on my raised drive
    Eibach Pro Kit lowering springs fitted
    Pipewerx 3" Downpipe
    Pipewerx Sports Cat
    Milltek Resonated Catback Exhaust
    Revo Stage 2 upgrade
    All the recent additions has transformed the car even more than Stage 1. The mid range torque is ridiculous.
    I have got an SPS Switch so did some testing with different settings.
    The SPS settings for Stage 1 were Boost 8, Timing 4 and Fuel 6.
    When Stage 2 was uploaded the settings were changed to Boost 7, Timing 6 and Fuel 9.
    I did a couple of runs with the settings as Boost 9, Timing 6 and Fuel 9, and the car was insane. It felt like a proper animal.
    I changed the settings back to Boost 7, Timing 6, and Fuel 9 for conservative reliability as I need to get my FMIC fitted and book in for Forged rods in the New Year. I don't fancy making new holes in my engine or bending rods.
  26. Dan-Jnr
    1,234
    386
    Couple of pictures of the recent additions.
  27. dre_S3
    dre_S3 Member
    756
    39
    Looking good Dan :yes:
  28. Dan-Jnr
    1,234
    386
    Went to Badger5 before I went to Australia in February to have my AH Fabs 1.5 intercooler fitted.
    Wasn't straight forward as my crash bar had already been cut but there was enough metal to fit the intercooler.
    Anyway great service from the guys and recommend them to anyway.
    Since having it fitted my cruising air in take temp sits between 6° and 10°, and during fullboost it raises to 21° to 25°
    I also had a Forge MBC fitted to clip my boost spiking past 22psi. This should save turbo and reduce the chances of bent rods.
  29. Goubo1
    Goubo1 Well-Known Member
    958
    297
    What power is your car making dan ? and it looks cracking :)
  30. Dan-Jnr
    1,234
    386
    When I had my Eibach springs fitted the garage removed the OEM rubber spring pads and replaced with the Eibach spring pads.
    This caused the car to sit incorrectly.
    The OEM ones have to remain as well as the Eibach spring pads.
    The car now sits perfectly.
    Eibach spring pads only
    OEM and Eibach spring pads
  31. ap
    ap Member
    Dan-Jnr just read through your thread, you have a very nice car and a credit to you
    Andy
    Dan-Jnr likes this.
  32. Dan-Jnr
    1,234
    386
    Spent last Sunday afternoon washing, claying, polishing and waxing, then after 5 hours and not being able to find my tyre shine (well annoyed) produced this.
  33. S3quatt
    652
    60
    Looking good!
    Dan-Jnr likes this.
  34. Dan-Jnr
    1,234
    386
    Time has come to put my S3 back to stock configuration to sell, apart from lowering springs, Revo Stage 1, and RNS-E.
    Car will be up for sale from tomorrow night, parts will be added to classifieds this week.
    So out with the old and in with the new.
  35. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Boooooooooooooo!
    Nice choice of colour though!
    Westy likes this.
  36. [Dave B]
    [Dave B] Daddy
    2,027
    145
    This is interesting, I'm pretty sure I just replaced my spring pads with the Eibach ones.....did you leave both the top and bottom spring pads in (both the flat ones)?
  37. s3mad_dude
    s3mad_dude Noggies ruuuule!
    619
    79
    Nooo another noggy leaves. Oh well, at least you got a proper colour for the 8P and not the usual boring black/grey/white. I saw this one advertised and it caught my eye too ;-)
  38. Dan-Jnr
    1,234
    386
    The car is now up back to standard configuration apart from Revo Stage 1 and Eibach lowering springs.
    It's now up for sale, and most modified parts are in the classified section.
