BLOCKED DRAIN PLUG??
Audibird Jul 15, 2007
  1. Audibird
    Audibird New Member
    15
    Got A6 Avant, parked under trees in father in laws garden for two weeks while on holiday now I've got water coming into car and the rear of the engine bay is filling up with water just under the battery compartment. Is there any drainage holes in the engine bay that could have been blocked by the dratted pines needles? :sadlike:
  2. simonwjones
    simonwjones Member
    365
    Theres a drain hole underneath the batery and also check where the windows pilars drop down behind the front wheel arches.
    Its a common problem, just clear them out.
    You had also better check the rear passenger footwell for water as well, as this is a symptom of having clogged drain holes as well.
    Clear them out, dry out any affected areas and you should be ok
    Simon
  3. shineydave
    shineydave Member
    920
    isn't there 2 drains, one under the battery and one under the servo?
  4. Audibird
    Audibird New Member
    15
    Thanks guys will take a look:icon_thumright:
