block 125
sandwich1987
Scotland Dumbarton
Ive been having issues with my abs.... i.e abs light traction control light and the fault code 01316, implying a communications fault. Ross tech tells you to chech blocks 125 and onwards. It doesnt however tell you what values you should be getting im getting a value of 1 under the abs field but have no idea what this actually indicates????
http://www.ross-tech.com/vag-com/m_blocks/120-129.html
01316 - Ross-Tech Wiki
01316 - ABS Control Module: No Signal/Communication
Possible Causes
Wiring/Connector(s) from/to ABS Control Module faulty
Fault(s) stored in ABS Control Module
Possible Solutions
Check Wiring/Connector(s) from/to ABS Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
Can you connect to the ABS control module in VCDS (03 - ABS Brakes)?
it was mapped at r-tech. i've been to block 125 and the boxes say gearbox abs and intsrument cluster. i have no value under the gearbox coloum and 1's in both the abs and instrument cluster, but am unsure if this is a good thing. I cant access the abs using my ebay cable, so im waiting on a ross tech one coming. Im only getting this code on the AWD module.
Any ideas...
978
29
714
23
6K
