Bleeding brakes
chaz20vt Oct 1, 2013
  1. chaz20vt
    chaz20vt Member
    428
    21
    Iv got myself a gunson eezibleed kit hoping to bleed my brake
    Is it just a case of connecting it to a spare tyre at 20psi then connect to brake resourvour and undo each nipple at a time?
    Do i need to do both nipple on the master cylinder
    O have searched but no definite answer to what i need to know
    Thanks in advance
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Are you flushing the system or just bleeding a certain corner?, if the master cylinder has not gone dry you shouldnt need to touch it...
    Is 20 psi on the instructions? seems quite high
  3. <tuffty/>
    20,847
    3,687
    Gunson say a max of 20psi iirc... I normally use 15psi...
    The bleeder has instructions does it not for normal bleeding operation?
    I normally bleed drivers side rear, passenger side rear, drivers side front, passenger side front then both MC nipples/// but as Dave said there shouldn't be any reason to do the MC unless after a full bleed the pedal travel is still long... have done a few full bleeds that have not dropped the level in the reservoir but still needed the MC to be bleed to get the pedal up... I would advise bleeding the clutch too as this uses the same fluid
  4. chaz20vt
    chaz20vt Member
    428
    21
    Thanks for that guys
  5. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    To bleed the clutch, is it the single bleed nipple on top of the gear box housing?
    Liam
