Hi guys
Thought I'd try this here as I'm not getting any response on the tech forum.
Just got my first Audi a B6 1.8T QS and it's pretty good, however, I bought the thing with a duff thermostat which is now replaced and the problem solved but I can't seem to get the coolant system to bleed properly, Heater does not blow hot until the engine is above about 3000 rpm then it works perfect I've bled it threw the screw on the coolant pipe and through the hole in the heater hose with the engine running and heater on HI but still it only blows cold at idle.
Any ideas or suggestions most appreciated
cheers
Marcos
cheers
Marcos
