blanking off rear wiper need to stop "water"r from working
sykotikman Mar 5, 2013
  1. sykotikman
    sykotikman New Member
    hi
    can any one please help me ,
    i'v just ordered a part to fill the hole where the rear wiper is ,(removing the arm and motor)< knackered
    now when i take out the washer motor and leave the water pipe hanging , if i accidentally press the stork to activate the rear washer i'm going to have water all over the boot
    i'v tried taking out the fuse but it also stops the front washers from working ,
    is there any thing i can do ?
    a3 2.0 tdi sline 04 plate
    thank you
  2. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Put a bolt in the end? Pinch it with something? Tie it in a knot?
  3. Rom
    Rom Member VCDS Map User
    443
    Un plug the motor. Assuming it has separate rear motor.
  4. sykotikman
    not a bad idea mate "little bolt and jubilee clip"
    not sure i can only hear the washer motor noise coming from the front of the car and assuming it will just be long hose to the rear will have to have a dig around never thought about that ,
  5. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    Just about to do this myself. Was planning on squirting a little silicone into the pipe then screwing in a bolt whilst its still wet. Should ensure a watertight seal?
  6. sykotikman
    dont see why it wont work , i gather there wont be too much pressure coming from the pump ,but just have look around on the net and the hose coming from the washer bottle at the front of the car is made up of a few parts (not one long hose) so there could be a possible chance that one of these section could fail and start to leak water in to the car , if you/i press the stork long enough
    not that were going to as we know theres no washer motor at the back
    so going to try and find the hose that leads to the back of the car from the main washer bottle under the bonnet and see if can blank it off from there ,
    so if theres a chance of accidentally pressing the stork , it will only leak from under the bonnet and not in the car ....
  7. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    I don't think there's enough pressure to cause any problems. My nozzle has frozen over in icy weather in the past which stops the water from jetting out. I've held down the stalk hoping to get it to clear without causing any breakages or leaks from the pressure build up
  8. sykotikman
    probably a bit over kill from my part , a guess an easy fix could a bolt /screw silicon and jubilee clip ,
    my wiper seized up a good while ago and when trying to move it i broke the wiper, and to be honest iv never accidentally pressed the stalk in ( well i dont think i have :unsure:)
  9. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    Ye my wiper motor is knackered too. It's stuck halfway up the window.... I don't see the point in replacing the motor, it looks better without the wiper and I can't say I've missed not having one considering it hasn't worked since I bought the car.
    I bought a custom window plug from Designstopfen - Heckwischerabdeckung, Blindstopfen, Kappe, Glasstopfen, De-wiper, Plug, Grommet, Cap. Very expensive at £23 (especially when rubber grommets are a couple of pence) but the thought of having my football clubs logo on it was just too cool :blush:
  10. sykotikman
    ha ha
    that was the same place i ordered mine just the plain black glass one ,
    £23 was a bit much but tried to ordered one from dubmonkey.co.uk @£10 but couldnt get past the payment page so went the german company instead and got the glue with it ,,
    to replace the motor was going to be nearly £80 , just a bit too much for my liking ,
  11. Rom
    443
    I'd be very surprised if Audi use one motor for front and rear.
    It's pretty common to use separate front and back, though obviously both are at the front.
    Allows better motor life, and in a pinch, can swap pipes over until you replace the dud motor.
  12. phil77
    phil77 Member
    56
    I press mine and it fires straight out past the front of the engine haha I need a gromit ASAP. Anyone know of any company's in the north west that stock these?
