Black smoke :( EGR?
gmars70970 Mar 29, 2013
  1. gmars70970
    gmars70970 New Member
    Hi all,
    I've just bought a 2005 TDI avant s-line (140bph) starting to have problems already [​IMG] Hopefully somebody will be able to help.
    The car drives fine when under load. The problem seems to be when driving sensibly then accelerating, theres loads of black smoke out the back and lack of power, if I change down a gear and accelerate then theres no problem. Also today when I started the car it was smoking heavily, I had to gently convince it to rev up. It then ran fine again. Hope this makes sense [​IMG]
    Also, should you be able to feel suction from the pipe connected to the EGR valve? I can blow/suck into the pipe with no resistance.
    Any suggestions would be appreciated. Thanks in advance
    Graeme
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    get a diag test done to check for any codes
    it could have a split hose
  3. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    Did you buy the car from a friend or unknown person. Question I ask is........do you know the cars history? Has the DPF been deleted as the car would smoke alot more if it has been deleted. To the untrained eye you wouldn't have a clue it had been deleted if it was done properly.
  4. gmars70970
    I bought the car from a garage, the service book is fully stamped up originally by Carlisle Audi then recently by Ayr Audi VW Service Centre. Untrained eye..... I dont even know what dpf is never mind if its been removed lol.
  5. gupsterg
    gupsterg Active Member
    348
    Any update?
  6. gmars70970
    Hi,
    I had the EGR valve replaced. Totally solved the problem & runs perfectly now.
    The butterfly at the top of the EGR valve had came lose & was doing what it wanted.
    £230 supplied & fitted.
    Graeme
    gupsterg likes this.
